		rowil(at)clara.net Guest
				 Posted: Tue Jan 31, 2006 12:56 pm    Post subject: Mod 61 - Stall warner questionMod 61 - Stall warner questio |
				At 2006-01-30 09:56 -0800 Andrew Sarangan wrote:
  	  | Quote: | 	 		  I could not find Neville's posting in the archives on using a light
 bulb to locate the distance
 Andrew - I'm not sure who originally offered the idea, but here's the
 one that worked very easily for me - I certainly don't claim to be
 the originator.
 Once you've made your hole in the spar, place a very bright light in
 front of the wing leading edge (not too close, don't cook the wing!).
 You should be able to look forward through the spar hole and note
 that the light is shining through the leading edge skin. You may have
 to arrange things so that the light is not shining directly in your
 eyes above the wing skin while you're trying to squint through the
 hole. Now ask your beautiful assistant to hold up an opaque sheet
 (metal, wood, thick card) close to the LE. You should be able to see
 the edge of the shadow cast by the opaque sheet. Now ask the
 assistant (before she gets gets fed up & goes away again) to slide
 the sheet inboard or outboard on the wing LE until the edge of its
 shadow (as seen by you looking forwards through the spar hole) is in
 the desired position relative to the edge of the rib nose. Next she
 should use her marker pen to put a nice dot on the LE at the very
 edge of her opaque sheet. That's got the position fixed in one plane
 - nw use the template to fix the hole in the up/down direction.
 It is possible to do a similar process single-handed - but as all the
 best maths books say, this is left as an exercise for the student.
 regards
 Rowland
 | Rowland Carson  PFA #16532 <http://home.clara.net/rowil/aviation/>
 | 750 hours building Europa #435 G-ROWI  e-mail <rowil(at)clara.net>
		NevEyre(at)aol.com Guest
				 Posted: Tue Jan 31, 2006 1:11 pm    Post subject: Mod 61 - Stall warner questionMod 61 - Stall warner questio |
				A big [ D cell ] Maglite, sat on scrap foam, shining forward thru the hole
 in the spar works well if you have no pretty assistant to hand, get your head
 under a blanket, draped over the leading edge, and the rib will show up thru
 the  wing, where there is no foam present.
 Cheers,
 Nev; [ with no pretty assistant to hand !]
		Trevpond(at)aol.com Guest
				 Posted: Wed Feb 01, 2006 4:30 am    Post subject: Mod 61 - Stall warner questionMod 61 - Stall warner questio |
				Come on Nev, you've got Martin, or Sooty next door!
 Trev Pond
