noel(at)blueskyaviation.n Guest
Posted: Sat Dec 16, 2006 4:52 pm Post subject: smoking rivets |
Here are some drawings I did quickly to help picture acidental
countersinking of the base metal E
Noel
mail2web - Check your email from the web at
http://mail2web Ecom/ E
sheet_metal_class1.PDF |
189.82 KB |
187 Time(s) |
sheet_metal_class.PDF |
42.51 KB |
226 Time(s) |
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Tue Dec 19, 2006 12:13 am Post subject: smoking rivets |
Nice visual with the drawings. Thanks for taking the time.
Kevin
40494
tail/empennage
_________________ Kevin
40494
do not archive |
rwshooter(at)cox.net Guest
Posted: Tue Dec 19, 2006 3:54 am Post subject: smoking rivets |
Hey Noel,
Could you resend those rivet drawings. I couldn't open due to "corrupted"
file..
Thanks.
Robb
192RL....reserved
Posted: Tue Dec 19, 2006 7:36 am Post subject: smoking rivets |
Try these, if you can't open them someone else with greater computer skills
than I will have to intervene.
Noel
sheet_metal_class.pdf |
42.51 KB |
199 Time(s) |
sheet_metal_class1.pdf |
189.82 KB |
213 Time(s) |
