grabo172
Posted: Sun Dec 10, 2006 6:35 pm Post subject: Electric Carb Heater? |
Where can one purchase one of those fancy electric carb heaters? I've been searching online and can only find plans from a fella on ebay...
I had a good episode in carb ice today on my 447. Climbing out at 45 mph at full throttle the RPMs suddenly were dropping out and when I leveled it out and throttled back I could feel the itermittent misses... In talking to a mechanic very familliar with Rotax and a few other sources, it most defidently was carb ice...
Anyone have a source for the electric carb heaters?
Thanks all,
Fly safe,
_________________ -Erik Grabowski
N?????
CFI/CFII/LS-I |
Arksey(at)aol.com Guest
Posted: Sun Dec 10, 2006 7:14 pm Post subject: Electric Carb Heater? |
go to this web site http://www.leadingedge-airfoils.com/
Products Manufacturer Model SKU Price Engine Carburetors, Electric Dual Bing Carb Heater Bing J9114 $259.95 It is a bit pricey....I do not know anything about them...have never used it, but am interested in any info from people who have., or anything else pertaining to carb. ice in 2 cycle rotax engine . People I have talked with about carb ice in the 2 cycle go from people who have had no problem to people who believe they have...nearly all have had forced landings, some think it was caused by carb ice others dont think so. I am in the process of studying the issue and will report and info If I feel it usefull.
Jim Swan firestar ll 503 we are now in Florida and about to do some flying.
planecrazzzy Guest
Posted: Mon Dec 11, 2006 3:02 pm Post subject: Re: Electric Carb Heater? |
Looks like the price came down...
They used to be over 300 bucks
Gotta Fly...
Mike in MN
Posted: Mon Dec 11, 2006 3:13 pm Post subject: Electric Carb Heater? |
| Gotta Fly...
| Mike in MN
Mike:
Do they work?
_________________ John Hauck
Titus, Alabama |
grabo172
Posted: Mon Dec 11, 2006 5:24 pm Post subject: Re: Electric Carb Heater? |
That ones for a liquid cooled engine... maybe a 912... I don't have any water in my 447...
I know they exist... I just can't find one. Maybe I will have to buy the plans and build one myself from the guy off ebay...
Check it out and see what you think.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220058124473
N?????
CFI/CFII/LS-I |
a58r(at)verizon.net Guest
Posted: Mon Dec 11, 2006 6:38 pm Post subject: Electric Carb Heater? |
Long time ago there was an elect carb htr made/sold by a guy in
Alaska. don't remember what eng/carb it was for. Archive?
regards,
Bob N. FireFly 070 Old Kolb
d-m-hague(at)comcast.net Guest
Posted: Mon Dec 11, 2006 7:00 pm Post subject: Electric Carb Heater? |
All this talk of carb icing... I had carb heat in my T-Craft, of course,
but not in the 503 powered borrowed Quicksilver I was flying until
recently, nor the PPG's (and it never seemed to be a problem)... what about
the Cuyuna (I'm buying a Cuyuna powered Ultrastar)?
Of course an electric carb heater isn't an option on a plane with no
electric...
-Dana
For people who like peace and quiet: a phoneless cord.
planecrazzzy Guest
Posted: Tue Dec 12, 2006 2:55 pm Post subject: Re: Electric Carb Heater? |
Hi John,
Back when I had to "put Down" because Carb Ice had my engine running slow & ruff , I started looking into a Carb Heat...
I thought it was Aircraft Spruce who stocked them....for around $350
( Dual Carbs )
I "DID" talk to somebody that had them on their carbs , they said that it robbed a little power , but he hadn't had the problem again....
it's more or less an electric "vest" for your carbs....
I guess the power loss is from warm air....?
I'm gonna see if I can hunt down the ones I'm talking about.....
and they were made for ROTAX
Gotta Fly...
Mike & "Jaz" in MN
PS a picture of my new TIG machine / Next plane W-10 Tailwind
| John Hauck wrote: | | They used to be over 300 bucks
| Gotta Fly...
| Mike in MN
Mike:
Do they work?
mkIII |
| Description: |
| My NEW Miller Syncrowave 250 DX |
| Filesize: |
44.49 KB |
| Viewed: |
678 Time(s) |
Posted: Tue Dec 12, 2006 5:21 pm Post subject: Electric Carb Heater? |
At 05:55 PM 12/12/2006, planecrazzzy wrote:
| Quote: | I "DID" talk to somebody that had them on their carbs , they said that
Sure, you will have some power loss when you use carb heat; in fact that's
how you check that it's working (rpm drop) during your runup. But you
don't use it all the time, just for partial throttle operations (i.e.
descent and landing) since that's when you're susceptible to carb icing...
it's rarely a problem at cruise power or above.
-Dana
My software never has bugs. It just develops random features.
planecrazzzy Guest
Posted: Tue Dec 12, 2006 6:06 pm Post subject: Re: Electric Carb Heater? |
When I got "My" Carb Ice....it was on Take-off
The Carb Heat that I was trying to look up can't be found.... I do remember that it was on "all" the time....
I saw the one listed in L.E.A.F. , I like the stuff that goes with it....A switch and indicator light... That way you wouldn't have to have it on all the time....
When I got carb ice , I circled back to the runway.....hoping that the engine would "Clear" , but it didn't , I circled a couple of times , but I was coming down....not enough power.... I haven't gotten carb ice since...
( that was my Powered Parachute / 582 )
But I think the carb heat would have had time to work....
I don't think it would be that hard to make a carb heat box , using a little plumbing from the exaust tubing....
I think I saw the temp needed is around 90 degrees , that shouldn't be hard to do...
Gotta Fly...
Mike & "Jaz" in MN
| Description: |
| Option boards on the right side of the panel are Cool ( Pulser & Sequencer) |
| Filesize: |
60.12 KB |
| Viewed: |
638 Time(s) |
rlaird
Posted: Wed Dec 13, 2006 10:14 am Post subject: Electric Carb Heater? |
What I've heard (and this is really a question, not a contribution) is
that heating the carb body (via water or electric) is better than the
"GA method" because the GA method routes hot air into the carb, which
lessens the power... but that heating the carb body prevents ice from
forming but which results in minimal air heating, thus trivial loss of
power compared to the GA method.
Does this sound right?
-- Robert
On 12/12/06, planecrazzzy <planecrazzzy(at)yahoo.com> wrote:
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Wed Dec 13, 2006 10:53 am Post subject: Electric Carb Heater? |
Robert, both approaches will reduce the volume of the air charge
reaching
the cylinders but the water heater is superior. Naturally depends on
whether
you have hot water available.
This is my homemade water heater strapped to my homemade intake
manifold.
It was an after the fact fix to both help vaporization and prevent carb
ice.
Works well.
BB
| Description: |
| Filesize: |
174.24 KB |
| Viewed: |
786 Time(s) |
jindoguy(at)gmail.com Guest
Posted: Wed Dec 13, 2006 11:15 am Post subject: Electric Carb Heater? |
What are you running for a carb? Looks like an old one barrel Holley.
Rick
On 12/13/06, robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote: | Quote: | Robert, both approaches will reduce the volume of the air charge
reaching
whether
manifold.
ice.
Works well.
BB
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
rlaird
Posted: Wed Dec 13, 2006 11:18 am Post subject: Electric Carb Heater? |
Bob --
Why is the water heater superior? If the water is, say, at 180
degrees, and an electrical system generates, say, 90-degrees, (or 180
if you twist the rheostat!), then why would the water heater system be
superior? (This isn't rhetorical... I really want to know!
-- Robert
P.S. Gee, how often does one get to use TWO words starting with "rh"
in the same email? hehehehe
reaching
whether
manifold.
ice.
Works well.
BB
Robert Laird
Houston, TX area
Posted: Wed Dec 13, 2006 11:38 am Post subject: Electric Carb Heater? |
antique one barrel solex...
On 13, Dec 2006, at 2:15 PM, Richard Girard wrote:
| Quote: | What are you running for a carb? Looks like an old one barrel Holley.
Rick
On 12/13/06, robert bean <slyck(at)frontiernet.net > wrote:Robert, both
> reaching
> whether
> manifold.
> carb
> ice.
> Works well.
> BB
Rick Girard
"Ya'll drop on in"
when you live at the airport.
Posted: Wed Dec 13, 2006 11:48 am Post subject: Electric Carb Heater? |
RHEALLY now!
Maybe my isolated opinion, but in my case the heat gets added to the
incoming air after the venturi which maintains the volumetric capacity
of the (rather small) carb.
The heat from both the aluminum intake manifold and the saddled
muff transmits through the metal to the carb base, which is where
the chunks of frost generally tend to accumulate.
I remember frost forming at the carb base of an airplane engine
running on a test stand in Los Angeles at an OAT of 70F
It can happen to YOU!
BB, cobjobmeistergeokolb
On 13, Dec 2006, at 2:18 PM, Robert Laird wrote:
Bob --
-- Robert
> reaching
> whether
> manifold.
> carb
> ice.
> Works well.
> BB
