armywrights(at)adelphia.n Guest
Posted: Mon Dec 11, 2006 8:45 pm Post subject: clearance |
Anybody have a measurement from the ground to the belly of the aircraft, or how high do I need to hoist/jack the fuse up in order to slide the gear legs in?
Rob Wright
#392
Fuse
rene(at)felker.com Guest
Posted: Mon Dec 11, 2006 8:56 pm Post subject: clearance |
I do not have the measurement, but I had mine on top of a regular cafeteria table from the aviation department of Sams…..
Rene'
801-721-6080
Deems Davis
Posted: Tue Dec 12, 2006 10:10 am Post subject: clearance |
Rob, I don't know that anybody will have this information, because as
soon as you get the leg's inserted and the wheels on you take it down to
avoid the risk of an accident. But you can estimate it pretty easily, by
setting one of the gear legs parallel mounting tube, resting the leg on
the ground and then measuring how much the top of the leg extends beyond
the bottom of the gear tube. I just kept 'ratcheting it up' until I had
enough clearance.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Rob Wright wrote:
| Quote: | Anybody have a measurement from the ground to the belly of the
Rob Wright
#392
Fuse
