n616tb(at)btsapps.com Guest
Posted: Sun Dec 10, 2006 2:13 pm Post subject: High CHT problem - Hole found |
Walter,
Yes, I did see this and I looked at it determining I did not have this
problem. I redid the baffles on a little around this front area and again
determined for what ever reason this did not apply to me. After getting
your post and looking at it I understood a little better what you were
indicating. I just went out and stuck my hands up there and just felt
around for a couple minutes. Son of a gun, I do have a leak here, mostly on
the left side of the engine. How did I miss this? Thanks again. I will be
doing some glass work tomorrow. I know this has been brought up several
times, but if this does the trick, I owe you something cold whenever I meet
you.
[quote] --
walter(at)tondu.com Guest
Posted: Sun Dec 10, 2006 3:52 pm Post subject: High CHT problem - Hole found |
On 12/10 4:12, Tim Bryan wrote:
> I know this has been brought up several times, but if this does the trick,
> I owe you something cold whenever I meet you.
If the poll results apply here then you have an 80% chance of improving
your cooling. And I'm pretty thirsty
Walter Tondu
http://www.rv7-a.com - Flying!
http://www.evorocket.com - Building
