Posted: Mon Dec 11, 2006 8:51 pm Post subject: Wire routing--TUNNEL? |
So many people have discussed the hot tunnel temperatures associated with
their Lycoming heating and air system. First, is there any left over room
in the tunnel for anything, as in wire bundles, upper right and left
corners. Is the temperature in the tunnel so hot that is makes it an
impractical area to route anything except hot water to make cocoa on long
flights?
Thinking about putting in a third hole in the bulkheads above the main spar
Just thinking, Just asking.
John G.
flysrv10(at)gmail.com Guest
Posted: Tue Dec 12, 2006 3:52 am Post subject: Wire routing--TUNNEL? |
The tunnel in my 10 used to get hot to touch and I believe would burn your leg if you hold your leg against it long enough. I totally disconnected the left side heat muff and used a "Y" on the right side to bring cold air into the tunnel (via the left valve) and heated air for the cabin. During the summer I still had to stick rags into the heater outlets to prevent the hot air leaking into the cabin.
I have not done much more trouble shooting. I live in Florida and everything is HOT! Perhaps it is not as much of an issue elsewhere.
Rob Kermanj
On Dec 11, 2006, at 11:50 PM, John Gonzalez wrote:
[quote]--> RV10-List message posted by: "John Gonzalez" <indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)>
So many people have discussed the hot tunnel temperatures associated with their Lycoming heating and air system. First, is there any left over room in the tunnel for anything, as in wire bundles, upper right and left corners. Is the temperature in the tunnel so hot that is makes it an impractical area to route anything except hot water to make cocoa on long flights?
John G.
-- Please Support Your Lists This Month --
(And Get Some AWESOME FREE Gifts!)
November is the Annual List Fund Raiser. Click on
the Contribution link below to find out more about
this year's Terrific Free Incentive Gifts provided
by:
* AeroElectric www.aeroelectric.com
* The Builder's Bookstore www.buildersbooks.com
* Aeroware Enterprises www.kitlog.com
* HomebuiltHELP www.homebuilthelp.com
List Contribution Web Site
--> http://www.matronics.com/contribution
Thank you for your generous support!
-Matt Dralle, List Admin.
- The RV10-List Email Forum -
--> http://www.matronics.com/Navigator?RV10-List
Rick S.
Posted: Tue Dec 12, 2006 6:36 am Post subject: Wire routing--TUNNEL? |
Hot tunnel problems??? There is a problem with the tunnel getting hot?? Is this with the Corvair, Subaru or the Lycoming engine? ;p
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Posted: Tue Dec 12, 2006 6:58 am Post subject: Wire routing--TUNNEL? |
Mine is a Lycoming. It has to do (I think partially) with a pair of really great heater muffs on the exhaust.
Rob Kermanj
On Dec 12, 2006, at 9:35 AM, Rick wrote:
[quote]--> RV10-List message posted by: Rick <ricksked(at)earthlink.net (ricksked(at)earthlink.net)>
Rick S.
40185
by:
