Aileron stop
david_a_g_johnson(at)btin
PostPosted: Sat Dec 09, 2006 5:35 am    Post subject: Aileron stop Reply with quote
I wonder if there is anyone who is building from a CZAW kit who can help?
The Aileron Stop (6-B-17-7CZ) is shown on the drawings as 90mm high, the part supplied with the kit is 130mm high, which puts the top almost level with the torque tube. (the CZ version uses a stop at the rear end of the torque tube, I believe the ZAC version uses stops at the ailerons themselves).
I queried this with CZAW and was told to 'trim it to 105mm', not much use as it it a Z-section with a flange at each end!
How has anyone else got around this, or have I just been supplied with a duff part? (It is obviously not 6164 alloy - wrong colour)
Dave Johnson
flyingmike9
PostPosted: Sat Dec 09, 2006 2:06 pm    Post subject: Re: Aileron stop Reply with quote
hi there i am building the kit and this was there answer when i asked the same question
still a bit confuesd
but hope it helps
Dear Mike,
We used 6B17-7CZ before and we used it as a stop plate for the aileron deflection on the rear sheet of Torque Tube 6B17-4CZ. Now we rivet 6W10-4 directly on the rear wing spar (left+right) and this part works as a stop plate for aileron.
Zodiac xl
fuse 50% rotax engine
Martin Pohl
PostPosted: Fri Jan 26, 2007 2:17 am    Post subject: Re: Aileron stop Reply with quote
Hi Mike and everybody else
I am also wondering how to install the aileron stop (CZAW kit). I do have two parts 6W10-4 (see picture below) but don't know how and where to install. The drawing shows 6W10-4 as a different looking part...
Looking forward to any help Very Happy .
Martin
Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html
Tim Juhl
PostPosted: Fri Jan 26, 2007 8:56 am    Post subject: Re: Aileron stop Reply with quote
This is what the current XL plans show. The pictorial guide gives a different measurement outboard of rib 7 but the date on the plans is newer.
Tim Juhl
Aileron Stop
 Filesize:  44.18 KB
 Viewed:  624 Time(s)
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring!
Martin Pohl
PostPosted: Fri Jan 26, 2007 10:31 am    Post subject: Re: Aileron stop Reply with quote
Hi Tim
Thank you for the picture of the aileron stop-installation. I will recheck my plans...
Martin
Martin Pohl
Zodiac XL QBK
