armywrights(at)adelphia.n Guest
Posted: Fri Dec 08, 2006 9:25 pm Post subject: Paint experience |
How much experience did you (anyone) have prior to doing your own priming and then paint? I need to start planning. For the simplicity of the fuse interior, it seems that I can both prime and paint with an inexpensive gun (<$50 or<$75), then I can save up for a higher quality exterior gun after I fly for a while.
Questions:
How’s the learning curve?
How many practice pieces before committing?
What about gravity vs. standard fed guns? Meaning, how easy is it to manipulate the gun to all the nooks and crannys with such a big cup without losing paint flow?
Recommend pint or quart cup to cover the interior, or go with a touch-up gun? I see on Tim’s site that he only used about a quart total for the whole inside.
Rob Wright
#392
Fuse Access Covers
Tim(at)MyRV10.com Guest
Posted: Sat Dec 09, 2006 6:10 am Post subject: Paint experience |
Reply inline...
Rob Wright wrote:
Quote: | How much experience did you (anyone) have prior to doing your own
Questions:
The learning curve question is a very tough question. It could vary
greatly for people. I do believe that those who are priming their own
parts can benefit from the time spent priming, however. My advice is
if you don't feel really comfortable, have someone come over who is
when you get to the real painting, and give you a hand with some parts,
or at least critique you. Most people will know SOMEONE who they
can call who's painted things before, even if it's a friend of a
friend. So talk about it with those close to you and see who
knows who. Even if it cost you a couple hundred bucks for an off-duty
auto body person for a day, you'd learn things....and a professional
paid paint job will still be many THOUSANDS more.
Painting isn't too bad when you get the theory down and have some
practice. After doing the plane I painted and matched a couple of
car pieces too, including clearcoat. The only thing that didn't
turn out perfect is I did it in a dusty garage and got some dirt
in the clearcoat. If you have someone get you started, there's no
reason that you can't do a reasonable job. I'll never pay for a
car to be painted again, from what I've found now. So now my
wife can nail all the deer she wants.
Here's a good suggestion for you. I think the pressure pot guns would
do good for people on the main color, but we didn't use them. But,
the guy who helped me had a good trick. For the Sata guns we used,
they make a plastic liner disposable paint cup that has it's own
integral filter. It was awesome for doing even the undersides
of things, because as the paint got used, the liner collapsed, keeping
it void of air for the most part. This eliminated the issue. They
weren't too expensive, and it was nice to just throw away the liners
when done with a session. Again, a small cost compared to paying
a pro.
Incidently, keeping a paint job simple (which is what I consider mine
to be), can help make it easier. One large single color base followed
by 1 or 2 stripe colors isn't really a big deal. Actually, the color
stripes are even easier to do on top of the base, and I found the base
coat clearcoat to be even easier to work with in general. But I am
glad I went single stage on the main color.
whole inside.
The interior is harder to maneuver around than the exterior. I now own,
AFTER the fact, a nice SATA MiniJet with a smaller cup that would be
great for the small areas on the interior. I think you could use
either, but you'll want to put any inline hose filters somewhere
upstream a ways so the hose connects directly to the gun with a 10'
whip instead of quick connectors. That makes it easier to flex
around. I don't know what I'd do if I could do it all over again.
Probably use the minijet on the interior, since it's such a small
area.
Either way, when you paint the plane, you're going to mix up larger
batches of paint than what one gun cup will hold. You need to be able
to just pour more into the gun and carry on quick, in order to keep
painting along the wet edge on the larger parts. The good news is,
if you can't keep up and keep the edge wet, you can back up to a
seam or some spot and start that panel with a new edge. Anyway,
you just don't want to have to stop and mix more paint during a large
shoot if possible. It also might be nice, if you have the time
and space to do it, to do a couple major pieces at a time. Like
the day you do the fuselage, don't do anything else. Do the wings
another day. Then do the small parts another day. That helps
break things up.
For my next plane, I may even just plastic line my garage and do
the entire thing there, as the color striped we did there turned
out fine. I'd just need to get some blower/filter stuff set up
but I could do that cheap enough to still make the entire job
a bargain over a paid-for pro job. Mine isn't the prettiest
plane out there, but it still seems to look good to most
people from what I can tell.
Quote: |
Rob Wright
#392
Fuse Access Covers
n8vim(at)arrl.net Guest
Posted: Sat Dec 09, 2006 6:50 am Post subject: Paint experience |
Rob,
I use a Paasche airbrush for all the small pieces (anything other than a
skin), which keeps overspray down, wastes less paint, and lets you work
a boit slower this allowing you more precision in priming. For the
skins, it is too small, so I use a regular automotive touchup gun, but
the amount of paint that gets in the air is horrible compared to the
airbrush.
If you do go the airbrush route, make sure to get a few 3 or 6 oz. spray
jars and a large needle to spray the heavy paints. I use the airbrush at
70psi.
Oh, if you screw up a small part during priming, just toss the part in a
bucket of Acetone or MEK and it will remove it so you can try again
later. (after a week though, the PPG Epoxy paint won't dissolve!)
I am using PPG DP50LF Epoxy primer, with DP401 Catalyst.
-Jim 40384 (must..... get..... back.... to..... riveting..... bottom....
wing.... skins.... ! )
Questions:
Rob Wright
#392
Fuse Access Covers
rj_todd(at)yahoo.co.uk Guest
Posted: Sat Dec 09, 2006 7:00 am Post subject: Paint experience |
Hi Tim,
"they make a plastic liner disposable paint cup that
has it's own
undersides
collapsed, keeping
it void of air for the most part"
I think you're refering to the 3M PPS system here
which is available for most guns. I'm in the process
of getting it for my Sata Minijet 4 - been on order
for over two months, the distributor is currently
waiting for the mini-cups.
See
http://multimedia.mmm.com/mws/mediawebserver.dyn?6666660Zjcf6lVs6EVs66SeggCOrrrrQ-
or if this doesn't work then go to the 3M site and
search for PPS.
I think some one here mentioned this some months ago.
Best wishes,
Rodger
--- Tim Olson <Tim(at)MyRV10.com> wrote:
Quote: |
<Tim(at)MyRV10.com>
Reply inline...
doing your own
For the simplicity
> Questions:
priming their own
come over who is
SOMEONE who they
friend of a
and see who
and have some
matched a couple of
that didn't
got some dirt
started, there's no
never pay for a
So now my
how easy is it to
with such a big cup
use them. But,
Sata guns we used,
has it's own
undersides
collapsed, keeping
the issue. They
away the liners
compared to paying
a pro.
color base followed
Actually, the color
general. But I am
> whole inside.
cup that would be
you could use
filters somewhere
gun with a 10'
easier to flex
all over again.
such a small
area.
to mix up larger
You need to be able
in order to keep
The good news is,
back up to a
edge. Anyway,
have the time
time. Like
Do the wings
That helps
break things up.
garage and do
there turned
stuff set up
entire job
prettiest
most
> Thanks,
> Rob Wright
> #392
> Fuse Access Covers
Click on
about
provided
=== message truncated ===
___________________________________________________________
All new Yahoo! Mail "The new Interface is stunning in its simplicity and ease of use." - PC Magazine
http://uk.docs.yahoo.com/nowyoucan.html
bsponcil(at)belinblank.or Guest
Posted: Sat Dec 09, 2006 8:33 am Post subject: Paint experience |
This past summer I borrowed a HVLP system from a guy at our airport and shot my practice kit control surface just to see how good of a job I could do. The final result was pretty poor so I decided I'd just give up on that idea and let the pros do it for me.
Since then I bought an el-cheapo gun from Wally-World to shoot the interior surfaces of the tailcone skins with epoxy primer (I had until then been using rattle can stuff) and after shooting all of those skins and associated bulkheads I'm coming back around to the thought of shooting the paint myself.
It takes some time and experimentation to get the gun set up right and to figure out all of the other variables in the process but my guess is that by the time you've shot the tailcone and wings, you'll be much more confident in your ability and you'll have made all of the mistakes you need to make and figured out how to fix them.
It sounds like Rob is well beyond that point in his build so I'm not sure what to suggest as far a practice. Scrap aluminum from the junkyard? Old wheelbarrow? Helpfully suggest to the wife that the gargage doors need to be re-painted?
One thing I'll say is that el-cheapo gun has a TREMENDOUS amount of overspray. I'd swear that every flat surface in my garage has a 1/16" layer of grey dust on it.
-Brian
#40497
Iowa City, IA
rvbuilder(at)sausen.net Guest
Posted: Sat Dec 09, 2006 6:31 pm Post subject: Paint experience |
Use SprayGunDepot.com. I've used them a few times and never had a
problem. Got the PPS from them about a month ago along with adapters
for my guns. Haven't had a chance to use it yet though.
