bobf(at)feldtman.com Guest
Posted: Sun Dec 17, 2006 3:45 am Post subject: ground for starter bendix |
Anyone else had starter problems with LOM? I do need to re wire the ground on
the bendix, but the "belt tightener " screw on the supercharger is somewhat a
mystery. the LOM engine manual is not real explicit on how to adjust it.
bobf
| - The Matronics Lom-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lom-List |
Jeayers1(at)aol.com Guest
Posted: Sun Dec 17, 2006 11:09 am Post subject: ground for starter bendix |
Which engine do you have?
Starting is the weak side of my M332A engine. I understand there may be a larger starter solenoid. Mine has a 30mm diameter. There may be a 34mm diameter starter solenoid.
Jim Ayers
RV-3 LOM M332A 3 blade MT electric CS propeller
In a message dated 12/17/2006 3:46:29 AM Pacific Standard Time, bobf(at)feldtman.com writes:
Quote: | --> Lom-List message posted by: Robert Feldtman <bobf(at)feldtman.com>
bobf
Posted: Sun Dec 17, 2006 3:56 pm Post subject: ground for starter bendix |
On Sunday 17 December 2006 13:09, Jeayers1(at)aol.com wrote:
I have a 332B LOM on the glastar. It is a 12 volt system. It appears to me to
be a rather small bendix - probably the 30. I clearly have some ground issues
for the bendix and am redsigning the grounding wire - trying to use a ground
braid strap of copper instead of wire.
How do you adjust the "strap" adjustment screw on the top/side of the
supercharger. somtimes it feels or sounds like there is somthing binding and
that is why the starter doesn't turn it well, and gets hot. Other times it
spins great.
glad to finally meet another LOM owner!
bobf
Jim Ayers
on
somewhat a
bobf
