CrownLJ(at)verizon.net Guest
Posted: Fri Dec 08, 2006 5:41 am Post subject: Plugs solid tip loose |
Hi All,
This is a solid tip plug that has been in use for over 50hrs. Note that the whole tip assembly was becoming unscrewed from the ceramic. I now check them every time I check/clean the plugs. In 150 hrs, this one was the worse, and I found one other loose, but still very intact. I did not notice any performance difference. Both of the plugs were on the same cylinder position (different times). I think that I might have contributed by "safety" wrapping the wire caps too tight.
larry
11.55 KB |
266 Time(s) |
13.28 KB |
263 Time(s) |
tc9008(at)aol.com Guest
Posted: Fri Dec 08, 2006 6:04 am Post subject: Plugs solid tip loose |
So much for solid tip plugs. I have been using plugs from the motorcycle shop and gaping them myself. So far no problems on 170 hrs
Travis
582
