Forward Skin Access
Goto page 1, 2  Next
Jaybannist(at)cs.com
PostPosted: Mon Dec 04, 2006 10:17 am    Post subject: Forward Skin Access Reply with quote
I am in the process of adding an access panel to the forward top skin, to be able to access the back side of the instrument panel after construction is complete. This is for a 601XL. I have a drawing in pdf format showing how I am doing this. If you would like to see the drawing, please contact me directly.
Jay in Dallas
craig(at)craigandjean.com
PostPosted: Mon Dec 04, 2006 10:29 am    Post subject: Forward Skin Access Reply with quote
Why not post the file to the file archive section of this list?
-- Craig
amyvega2005(at)earthlink.
PostPosted: Mon Dec 04, 2006 10:46 am    Post subject: Forward Skin Access Reply with quote
Jay,
please shoot me an email of the panel, i'd love a copy.
Jvega(at)carterusa.com
Juan Vega, Jr.
Senior Vice President, Brokerage Services
CARTER ONCOR International
Cell: 813-784-7312
Juan Vega
Terry Phillips
PostPosted: Mon Dec 04, 2006 10:58 am    Post subject: Forward Skin Access Reply with quote
Jay
I would like a copy of the .pdf file. Thank you.
Terry
me directly.
Jay in Dallas
Terry Phillips
ttp44(at)rkymtn.net
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
PostPosted: Mon Dec 04, 2006 11:15 am    Post subject: Forward Skin Access Reply with quote
Jaun, Let me know what you think. - Jay
Juan Vega <amyvega2005(at)earthlink.net> wrote:
Jay,
Juan Vega, Jr.
Cell: 813-784-7312
Juan Vega
InstrAccess2.pdf
 Filename:  InstrAccess2.pdf
 Filesize:  53.99 KB
 Downloaded:  480 Time(s)
PostPosted: Mon Dec 04, 2006 11:16 am    Post subject: Forward Skin Access Reply with quote
Terry, Let me know what you think, - Jay
Terry Phillips <ttp44(at)rkymtn.net> wrote:
Jay
Terry
>me directly.
>Jay in Dallas
>Do not archive
Terry Phillips
ttp44(at)rkymtn.net
PostPosted: Mon Dec 04, 2006 11:23 am    Post subject: Forward Skin Access Reply with quote
Craig, Done. According to Dralle, it might not be available for a while. If you want to see it earlier, just let me know.
Jay
-- Craig
jhstarn(at)verizon.net
PostPosted: Mon Dec 04, 2006 11:37 am    Post subject: Forward Skin Access Reply with quote
That's because your latest post/question (see below) has now been archived
because you didn't have Do Not Archive in your message. This message, mine,
will not be in the archives because I imbedded the required three little
words within this post. AND this post of mine does not need repeated ever
again.....I
Hope. KABONG
PostPosted: Mon Dec 04, 2006 12:03 pm    Post subject: Forward Skin Access Reply with quote
Jay,
that looks pertty cool. I like it. I was thinking on putting the entire piece on nutplates so the whole thing would come off. Am I missing something that would not make that possible? I think yours maybe better idea becasue you don't have to remove the canopy. I am also thinking of cutting and trimming the "head chopping" sun leadge on the panel, and replacing it with a leather one like on Cessnas. I found a place that can custom make one for cheap price. ANy thoughts?
Juan
PostPosted: Mon Dec 04, 2006 12:07 pm    Post subject: Forward Skin Access Reply with quote
> That's because your latest post/question ...
What does "Do Not Archive" have to do with him posting his PDF to the *file*
(not message) archives?
Also - who died and made you Darth Vader?
-- Craig
PostPosted: Mon Dec 04, 2006 12:35 pm    Post subject: Forward Skin Access Reply with quote
A number of builders have made almost all of the forward skin removable. For
one example take a look at the pictures on Larry's site under "Canopy":
www.macsmachine.com
-- Craig
PostPosted: Mon Dec 04, 2006 12:39 pm    Post subject: Forward Skin Access Reply with quote
on the panel...
I'm planning on replacing the whole control panel lip with silicon baffle
material. The front skin will stop flush with the control panel.
-- Craig
dredmoody(at)cox.net
PostPosted: Mon Dec 04, 2006 1:06 pm    Post subject: Forward Skin Access Reply with quote
To make the aft edge of the forward skin more user friendly you can buy an appropriate length of clear poly tubing at a local hardware store, split it lengthwise, inject it with clear silicon sealer and slip it onto the edge. Cheap, lightweight, easy, and stays put once set.
Ed
---- Juan Vega <amyvega2005(at)earthlink.net> wrote:
Jay,
Juan
ccwacker(at)HOTMAIL.COM
PostPosted: Mon Dec 04, 2006 1:30 pm    Post subject: Forward Skin Access Reply with quote
I have made mine removabale with nut plates. I modified the top plate so
that the part that covers the canopy hinge stays with the fuselage taht way
the canopy does not need to be removed.
Chuck Wacker
N601CW Quick Build
[quote]From: Juan Vega <amyvega2005(at)earthlink.net>
Reply-To: zenith-list(at)matronics.com
Subject: Re: Forward Skin Access
Date: Mon, 4 Dec 2006 15:03:15 -0500 (GMT-05:00)
Jay,
Juan
PostPosted: Mon Dec 04, 2006 3:21 pm    Post subject: Forward Skin Access Reply with quote
chuck,
got any pics to share?
Juanm
larry(at)macsmachine.com
PostPosted: Mon Dec 04, 2006 5:10 pm    Post subject: Forward Skin Access Reply with quote
Juan,
You needn't use nut plates for such a panel. J-nuts that work with 6-32
screws can be used with considerable confidence. They are much cheaper
and don't let go. I've got them on my removable forward top skin and
I've had the top off probably a dozen times in two years and 85 hours of
flying my 601. On the leading edge overhanging the panel, I bent a
piece of 1/2-inch aluminum tube and used a Dremel cutter to cut a slit
on the edge and used 4 bent tabs to secure it with the same screws that
hold the forward top skin.
It's a much easier job, as you use almost 90 screws, but very secure and
the screws blend into the rivet heads.
http://www.macsmachine.com/images/largeassembly2/full/uclips.gif
http://www.macsmachine.com/images/cowling/full/firstcowlfitting.gif
http://www.macsmachine.com/images/completion/full/601ezclosefrtrt.gif
Larry McFarland - 601HDS at www.macsmachine.com
Juan Vega wrote:
Jay,
Juan
agbeyer(at)sbcglobal.net
PostPosted: Mon Dec 04, 2006 6:51 pm    Post subject: Forward Skin Access Reply with quote
Hi Guys,
Here are some pics of my inspection covers. I used floating nut plates.
Al from Oshkosh
601 HDS
 Filesize:  182.01 KB
 Viewed:  392 Time(s)
 Filesize:  196.57 KB
 Viewed:  419 Time(s)
 Filesize:  194.35 KB
 Viewed:  452 Time(s)
PostPosted: Mon Dec 04, 2006 7:26 pm    Post subject: Forward Skin Access Reply with quote
great website by the way, you need to send me the plans for that kick ass recumbant Bike!
Do you have close up pics of the portion of the turtle deck you riveted, the very end pieces adjacent to the canopy screw. I like your idea.
Juan
PostPosted: Mon Dec 04, 2006 7:27 pm    Post subject: Forward Skin Access Reply with quote
that is the cleanest job I have seen. Obviously you have built before. HOw did you get such smooth cuts on the frame in the first picture?
I believe that is the frame for the cover?
Juan
PostPosted: Mon Dec 04, 2006 7:35 pm    Post subject: Forward Skin Access Reply with quote
to the guy asking for the POH, if you go on the zenith website, and check in the builder's section, just put in password and login. in the 601xl update sewction is a full copy of a POH for a European model.
cheers
Juan
Goto page 1, 2  Next
Page 1 of 2
