Posted: Thu Nov 30, 2006 12:24 pm Post subject: Switch source |
For my new (remodelled) flaps system I need an (ON)-ON-(ON) Double Pole toggle switch which is designated by Bob Nuckols AeroElectric Connection by 2 -70 , and the B&C website seems not to sell it ( it would be part # S-700-2-70 ).
Anybody knows a source for that particular switch?
Carlos
Neal.George(at)hurlburt.a Guest
Posted: Thu Nov 30, 2006 12:50 pm Post subject: Switch source |
Carlos -
I believe I received a similar switch as part of my fuselage kit.
neal
RV-7 N8ZG
Carlos
[quote] [b]
nuckollsr(at)cox.net Guest
Posted: Thu Nov 30, 2006 2:25 pm Post subject: Switch source |
At 02:49 PM 11/30/2006 -0600, you wrote:
| Quote: | Carlos -
neal
RV-7 N8ZG
S-700-2-70 ).
Newark has one at:
http://tinyurl.com/soyjx
The Microswitch cross is 2NT1-70.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Thu Nov 30, 2006 3:48 pm Post subject: Switch source |
mprather(at)spro.net Guest
Posted: Thu Nov 30, 2006 4:11 pm Post subject: Switch source |
Seems like Neal was looking for a switch with momentary contacts - maybe
like (also at Newark):
http://tinyurl.com/uvv93
If that one isn't quite right, there are other (on)-on-(on) switches at
Newark, and their website is pretty nicely organized for finding things.
Matt-
<nuckollsr(at)cox.net>
>Carlos -
>neal
>RV-7 N8ZG
>S-700-2-70 ).
Newark has one at:
khorton01(at)rogers.com Guest
Posted: Thu Nov 30, 2006 4:58 pm Post subject: Switch source |
The datasheet for the Honeywell 2NT1-70 shows that it does have
momentary contacts, as Carlos needs.
Kevin Horton
On 30 Nov 2006, at 19:11, Matt Prather wrote:
<mprather(at)spro.net>
maybe
switches at
things.
Matt-
>> Carlos -
>> neal
>> RV-7 N8ZG
>> Double Pole
>> Connection
>> part #
>> S-700-2-70 ).
> Newark has one at:
> Bob . . .
Posted: Thu Nov 30, 2006 5:36 pm Post subject: Switch source |
Ahah.. I see that now. Thanks.
Matt-
<khorton01(at)rogers.com>
Kevin Horton
> maybe
> switches at
> things.
> Matt-
>>> Carlos -
>>> neal
>>> RV-7 N8ZG
>>> Double Pole
>>> Connection
>>> part #
>>> S-700-2-70 ).
>> Newark has one at:
>> Bob . . .
stein(at)steinair.com Guest
Posted: Thu Nov 30, 2006 6:37 pm Post subject: Switch source |
Why does this need to be an (on) on (on) switch instead of the plain old
common (on)off(on) flap switch? I guess I'm not aware of a flap system in
an RV that requires such a configuration and why a standard old flap switch
that we all have used on our RV's (supplied by Van's, us, etc..) for years
wouldn't work!? Please enlighten me....I'm just curious!
Cheers,
Stein.
[quote]--
Posted: Fri Dec 01, 2006 5:41 am Post subject: Switch source |
Answers in order of post appearance :
Matt
No problem with your misidentification. I will google it and try to find a
more favourable vendor.
Kevin
Thanks very much for your offer. If I cannot find a better source, I'll come
back and ask for your help from Canada.
Stein
No wonder you're curious. The reason I need this kind of switch is because
I'm installing the Flaps Positioning System that I bought from Aircraft
Extras, which calls for 3 switches : 1 selector switch between Automatic and
Manual operation ( SPDT On-On switch ), 1 Automatic Flaps switch ("normal"
SPDT (On)-Off-(On) ), which operates the flaps to stop where you programmed
it and automatically positions the elevator trim, and finally a Manual Flaps
switch, which is a back-up or emergency switch, to operate the flaps when
and if the system fails. This last switch connects the flap motor directly
to +12V and must be acomplished by 2 SPDT On-None-(On) switches, or (I
figured it out, I hope I'm right) by 1 DPDT (On)-On-(On), wich is what I'm
looking for
Richard
I surely got the flaps switch from Van's (although I couldn't find it -
well, I got it some 4 years ago), but as you can see from the above
explanation, it doesn't suit my need, unless I use a double relay board.
Also, thanks for your offer to get the switch for me. I'll get back if I
can't find it.
Aren't this internet groups so GREAT to get help and knowledge!!?
Carlos
Posted: Fri Dec 01, 2006 6:49 am Post subject: Switch source |
At 07:56 PM 11/30/2006 -0500, you wrote:
Kevin Horton
Yes, the -70 is momentary (spring loaded) out
of both extremes. It's also progressive transfer
contacts.
This functionality is attractive for the control
of PM motors where it's useful to put a dead short
across the motor when power is removed. This short
offers "dynamic braking" that reduces coasting after
power removal. See:
http://www.aeroelectric.com/PPS/Flight/Flaps_2.pdf
Not than in position shown, middle OFF, the motor
is shorted.
Given Carlo's position outside the US, it might
be easier to implement one of the alternative
flap control architectures. See:
http://www.aeroelectric.com/PPS/Flight/Flaps_3.pdf
Here, a couple of automotive SPDT relays (inexpensive
and available worldwide) are used to handle motor
current. Note here too that with relays in positions
shown (OFF) there is a dead short across the motor.
The relays are controlled by a single pole (ON)-OFF-(ON)
switch that is also inexpensive and more readily available
than the elegant but rarified 2-70.
Bob. . .
Posted: Fri Dec 01, 2006 6:59 am Post subject: Switch source |
At 01:38 PM 12/1/2006 +0000, you wrote:
<trigo(at)mail.telepac.pt>
Matt
Kevin
come back and ask for your help from Canada.
Stein
and Manual operation ( SPDT On-On switch ), 1 Automatic Flaps switch
("normal" SPDT (On)-Off-(On) ), which operates the flaps to stop where you
programmed it and automatically positions the elevator trim, and finally a
Manual Flaps switch, which is a back-up or emergency switch, to operate
the flaps when and if the system fails. This last switch connects the flap
motor directly to +12V and must be acomplished by 2 SPDT On-None-(On)
switches, or (I figured it out, I hope I'm right) by 1 DPDT (On)-On-(On),
wich is what I'm looking for
Hmmmm . . . how likely is it that an inability to move
flaps in this airplane presents a hazard to outcome of
the flight?
I am exceedingly suspicious of systems offered to the
OBAM community that add any kind of automation to the
movement of aerodynamic surfaces with motors. In the
heavy iron business we have rigorous protocols for
the design and testing of any motor driven flight surface.
The concerns are not for inability to move the surface
but for unintended and unanticipated motion during a
high risk phase of flight.
Too many designs offered to the OBAM aircraft community
worry about inability to move surfaces (as it seems with
your description). I've not flown many kinds of airplanes
but after the Cessna 150's got their flap extension angles
reduced from 40 to 30 degrees, there are no airplanes in
my experience that are likely to get into trouble by failure
of flaps to move from any current position. This includes
airplanes like our Premier I.
If I used an airplane in situations were high reliability,
positive control of flaps was desirable, the most attractive
systems are operated by a handle on the floor. As soon as
you start adding features for motor drive, automatic extension,
backups to backups, etc. I'm wondering if the "concerns"
for useful operation of flaps isn't generated more my
marketing hype than for convenient, reliable, low risk
use of flaps.
A part that is not installed on your airplane is not
at risk of failure and offers the lowest cost-of-ownership.
pgroell(at)yahoo.fr Guest
Posted: Fri Dec 01, 2006 7:45 am Post subject: Switch source |
| Quote: | >
> Stein
> because I'm installing the Flaps Positioning System that I bought
> from Aircraft Extras, which calls for 3 switches : 1 selector switch
> between Automatic and Manual operation ( SPDT On-On switch ), 1
> Automatic Flaps switch ("normal" SPDT (On)-Off-(On) ), which operates
> the flaps to stop where you programmed it and automatically positions
> the elevator trim, and finally a Manual Flaps switch, which is a
> back-up or emergency switch, to operate the flaps when and if the
> system fails. This last switch connects the flap motor directly to
> what I'm looking for.
Carlos,
I will be using the same system and have pretty much decided to delete
all the optional switches.
I think if the Flaps Positioning System fails, well I'll consider the
flaps have failed.
I consider that if you have electric flaps on an aircraft you have to be
trained to use your machine without flaps.
I think adding all backup hardware is looking for more trouble.
My 0.02 cents,
Pascal GROELL
RV-7A #72588
www.notreavion.net
Posted: Sat Dec 02, 2006 5:25 am Post subject: Switch source |
Posted: Sat Dec 02, 2006 10:46 am Post subject: Switch source |
Posted: Sat Dec 02, 2006 11:53 am Post subject: Switch source |
| Quote: | Hope I we can meet one day on this side of the Atlantic.
Pascal
And where exactly are you building ?
Next January I will go to Barcelona and do some skiing in the Pyrinées, so
if you are in south of France ....
Carlos
Posted: Sun Dec 03, 2006 6:58 am Post subject: Switch source |
On 2 Dec 2006, at 08:23, Carlos Trigo wrote:
- You are in short final to any kind of airfield, with
your flaps deployed at maximum, and suddenly some obstacle occupies
your runway. If your FPS fails, how are you going to go-around?
Although I'm aware these are low probability situations, they are
nevertheless some reasons why I want to have back-up/emergency
manual control of my flaps
As Pascal indicated, there are many possible reasons why flap systems
may fail. If it is not possible to safely do a go-around with the
flaps fully extended, this suggests that the maximum flap angle is
too great.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
