rparigor(at)suffolk.lib.n Guest
Posted: Thu Nov 30, 2006 9:01 am Post subject: Cooling diffuser |
Has anyone changed the cooling air intake location and shape (diffuser)
for a XS / Rotax install?
It seems that if the duct was slight shorter with a proper shaped lip,
something like the Katana Extreme photo attached, may be a better
mousetrap??
By having the entrance of the diffuser airfoil shaped, if done properly
with the flat side on the inside, it could decrease speed and increase
pressure which is exact what we want, and even give a bit of forward
thrust.
Also included a picture of Gilles diffuser.
Ron P.
18.09 KB |
307 Time(s) |
59.32 KB |
303 Time(s) |
kpaviat(at)verizon.net Guest
Posted: Thu Nov 30, 2006 12:15 pm Post subject: Cooling diffuser |
Hello Ron!
You are correct to assume the XS cowling cooling intake will not work
properly if just using the raw edges as-is after cutting the shape out of
the front of the cowling. It is important to smooth the incoming air. You
can call me directly for some detail about this (I just don't have the time
right now to publish a complete dissertation about the Southern California
experiments....)
Kp
909-437-5151
karelvranken(at)hotmail.c Guest
Posted: Thu Nov 30, 2006 2:17 pm Post subject: Cooling diffuser |
Hello Ron,
Yes I changed the cooling air intake and the shape of the cowling on my XS.
At the moment the results are good. But we anyway need a controlable system
for the changing conditions and temperatures. I am working on a dynamic
balanced flap attached to the existing cooling duct aft of the oil radiator
and fitting in the cowling. At the moment it's to early to show what I am
doing because I need more tests and experience in flap control. Something
for long winter evenings. But if the papermen find that this is a
modification needing formulas and engineering reports than I put on the good
old cowling as ugly as it is.
Karel Vranken, F-PKRL # 447 XS Rotax 912 ULS, Airmaster CSU only 16 hours
and waiting for the papermen's final certificate.
Gilles.Thesee(at)ac-greno Guest
Posted: Thu Nov 30, 2006 3:20 pm Post subject: Cooling diffuser |
Ron and all,
| Quote: | Also included a picture of Gilles diffuser.
For those interested, here is some info on the research I did on the
cooling of the 914
In (hopefully understandable) English :
http://contrails.free.fr/engine_aerodyn_radia_en.php
http://contrails.free.fr/tunnel_en.php
Still in French for some time :
http://contrails.free.fr/engine_air_inlets.php
http://contrails.free.fr/engine_liquide_refroid.php
Some pictures of our cowling
http://contrails.free.fr/diap/phpslideshow.php?directory=diapo_capot_if
Hope this helps,
Gilles
Posted: Thu Nov 30, 2006 3:39 pm Post subject: Cooling diffuser |
Gilles
It certainly does help. Have you had any discussions with Kim Prout? I
would love to listen to a conference between you two and Kim's father Paul.
How often do things have to be invented more than once?
Graham
Gilles Thesee wrote:
| Quote: | For those interested, here is some info on the research I did on the
cooling of the 914
Hope this helps,
Gilles
hagargs(at)earthlink.net Guest
Posted: Thu Nov 30, 2006 6:28 pm Post subject: Cooling diffuser |
Ron:
I have changed the intake nostrils on the cowl to the 914 and have had
very good luck with keeping it cool in the AZ heat. The original round
configuration has the exhaust headers centered in the hole without much
view of the cylinder fins. I opened up each hole to the inboard side
about 1 inch having the radius decrease as it got closer to the inboard
side. Now each nostril is egg shaped with a commanding view of each
cylinder fin bank. Special pains were made to extend the lip of the new
portion of the hole inside of the cowling to avoid having the air spill
off of the inside edge and become turbulent. The length of the edge
toward the innermost side of each hole is about an inch deep. It makes for
good airflow toward the cylinder fins and presents a good appearance from
the outside.
Steve Hagar
A143
Mesa, AZ
20 hours of flight testing
Steve Hagar
air.guerner(at)wanadoo.fr Guest
Posted: Fri Dec 01, 2006 1:33 pm Post subject: Cooling diffuser |
Bonjour Gilles,<?xml:namespace prefix = noxml /><?xml:namespace prefix = o />
Your web site is full of very interesting experiments and test results I always enjoy reading.
Regarding engine cooling, it seems everybody agrees that the design of the cowling of the Europa XS is far from optimum and MCRs, especially yours, are a lot better regarding cooling drag and efficiency in flight . But I am just curious to know how it performs ON THE GROUND. Do you have any measurement available such as CHT vs time from a cold start, at a given OAT, with the engine running at high idle, in no wind condition? Do you get a CHT stabilization ?
Remi Guerner
Europa F-PGKL [quote][b]
Posted: Fri Dec 01, 2006 2:57 pm Post subject: Cooling diffuser |
Salut Rémi,
| Quote: | But I am just curious to know how it performs ON THE GROUND. Do you
Thanks for the kind words.
No problem on the ground.
During first run ups we ran the engine as long as 30 minutes continuous
with several full power runs then fast idle periods.
I did not take special measurements on the ground, only monitoring CHT
during warm up, taxi, etc...The aircraft was test flown from - 14°C to +
37°C OAT.
I can do take the measurements you require when flying with a helpful
passenger, but since we're in autumn, you'll have to wait until summer
for hot day conditions.
Best regards,
Gilles
Posted: Fri Dec 01, 2006 3:27 pm Post subject: Cooling diffuser |
Graham,
Paul.
Thank you for your message.
I never discussed with Kim, but the research and discussions (lots of
them) were most interesting. The knowledge on radiator cooling is at
hand, all we have to do is share what we have learned.
Best regards,
Gilles
Posted: Sun Dec 03, 2006 4:24 am Post subject: Cooling diffuser |
Salut Gilles,
My question regarding cooling on the ground is because all Rotax equipped Europas are known to overheat very quickly on the ground. I know some guys who say they do not overheat, but I have often observed them taxiing very fast to the holding point to be sure they are aloft before reaching the boiling point. Again the design of the Europa cowl is not optimal but cooling in flight is very effective. On the ground however it does not work properly. I am now convinced that the main cause for this poor cooling on the ground is the propeller. Most Europas are fitted with <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />Warp Drive props or Airmaster hub Warp Drive blades combination. Those blades are narrow at the root and not very much twisted. Therefore they do not provide a lot of air flow where the air inlets are located. On the other hand, most MCR are using the MT prop whose design is just the opposite: very wide blades at the root and a lot of twist which is a lot more effective ventilator. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
My own fix for the Europa cowling is a variable air scoop, below the existing inlet, ahead of the radiator. Theoretically it is very bad, but it works! It works because this additional inlet is located farther from the propeller axis, therefore receiving more air flow. Sure this adds a lot of drag, but who cares about drag during taxi and run-up? The scoop is positioned back to neutral just before take off and can be closed to blank the radiators at cruise and descent at cold temperatures.
Remi Guerner
Europa F-PGKL
during warm up, taxi, etc...The aircraft was test flown from - 14C to +
37C OAT.
Best regards,
Gilles
Posted: Sun Dec 03, 2006 5:04 pm Post subject: Cooling diffuser |
Remi
Another way to improve cooling on the ground is exhaust extraction, this
is how the EZ boys do it. I don't think anyone has tried it yet on a Europa.
You are right about the Warp Drive props. I had an Arplast PV50, nice
smooth rnning prop and better cooling. Ernst Keppert has the fixed
pitch Arplast which has the same blades and I don't think he has any
problems cooling on the ground either. I should say he has Classic
Europa, not quite the same
Graham
Rémi Guerner wrote:
Salut Gilles,
Remi Guerner
Europa F-PGKL
Posted: Sun Dec 03, 2006 9:44 pm Post subject: Cooling diffuser |
Hello Graham
"> Another way to improve cooling on the ground is exhaust extraction,
this
| Quote: | is how the EZ boys do it. I don't think anyone has tried it yet on a Europa."
How exact is exhaust extraction accomplished on EZ?
How about spraying water on the radiator during extended ground operations
and temps creep high, anyone try this?
Ron Parigoris
Posted: Mon Dec 04, 2006 3:22 am Post subject: Cooling diffuser |
Ron
I will attach a pik. Problem with Europas is the gases can get sucked
into the cabin, but that could be cured I'm sure.
Graham
rparigor(at)suffolk.lib.ny.us wrote:
| Quote: | Hello Graham
this
Ron Parigoris
293.94 KB |
286 Time(s) |
robh(at)hyperion-ef.us Guest
Posted: Mon Dec 04, 2006 7:49 am Post subject: Cooling diffuser |
In re: water spray
It's been a long time since I studied heat transfer but I recall enough of
the principles (if not the details) to know that there are a couple of
conflicting factors with this proposal. On the plus side, a fine mist of
water will provide some evaporative cooling, since the phase change from
liquid to gas will remove much more heat than liquid water flowing through
the air spaces in the "radiator" (a heat exchanger in engineering speak).
Also on the plus side is the fact that heat transfer to water is more
efficient than heat transfer to air. So far, so good. The big negative
here is the impediment to air flow - put any amount of water in the spaces
where the air is supposed to flow and less air can flow resulting in less
efficient cooling. It's worth a try but I expect that spraying water will
cause coolant temperature to rise not fall.
Best regards,
Rob Housman
A070
Airframe complete
Irvine, CA
nwcmc(at)tiscali.co.uk Guest
Posted: Tue Dec 05, 2006 5:55 am Post subject: Cooling diffuser |
| Quote: | My question regarding cooling on the ground is because all Rotax equipped Europas are known to overheat very quickly on the ground. I know some guys who say they do not overheat, but I have often observed them taxiing very fast to the holding point to be sure they are aloft before reaching the boiling point. Again the design of the Europa cowl is not optimal but cooling in flight is very effective. On the ground however it does not work properly. I am now convinced that the main cause for this poor cooling on the ground is the propeller. Most Europas are fitted with Warp Drive props or Airmaster hub Warp Drive blades combination. Those blades are narrow at the root and not very much twisted. Therefore they do not provide a lot of air flow where the air inlets are located. On the other hand, most MCR are using the MT prop whose design is just the opposite: very wide blades at the root and a lot of twist which is a lot more effective ventilator. <
I think Remi’s idea of using the cooler flap to increase cooling on the ground and reduce it in the air is great. However, although I have a Rotax 912S with Airmaster prop, I do not get significant cooling problems on the ground even when the OAT is up to 30degC. Cooling and cowl design seems to be one of those areas where even with identical setups we all get different results. One thing that is certain with the Rotax is that it has a tendency to get hot when the initial flight testing is done in the summer months. I found that the engine took about 25 hours to run-in fully, after which the oil and coolant temperatures dropped significantly.
Nigel Charles [quote] [b]
Posted: Thu Dec 07, 2006 12:59 pm Post subject: Cooling diffuser |
Salut Rémi and all,
Been much too busy those past few days.
Slowly catching up on the cooling conversation. Many valuable inputs indeed.
| Quote: | ... Therefore they do not provide a lot of air flow where the air
True. Now this is much less of an issue when the inlet is located far
from the propeller center line,at the bottom of the cowl, for instance.
| Quote: | My own fix for the Europa cowling is a variable air scoop, below the
cold temperatures.
I wanted to be sure to build up as much static pressure in the intake to
cool efficiently, and still have enough pressure left after crossing the
radiator, to exit at as high a velocity as practical. The goal was to
cool and still achieve lower drag.
Gilles
