Wingrider
Joined: 22 Nov 2006 Posts: 34 Location: Tullahoma, TN
Posted: Thu Nov 30, 2006 6:08 am Post subject: Alternator Recommendations |
Hi, I am new to the Matronics newsgroups although I have been reading the post for a while this is my first time writing in.
I'm building a Zenith 601HDS and will probably go with William Wynne's Corvair conversion. I'm trying to figure my electrical loads before installing the landing lights and closing up the wings and don't believe the typical JD garden tractor alternator is sufficient for my application; I expect a full load amp draw of between 35 and 40 amps. Maybe I'm way off base and maybe I shouldn't use a pair of 100 watt off road lights for landing lights.
I'd like your recommendations for a small lightweight automotive alternator. From what I’ve read it sounds like I should stick with the three wire alternators and shy away from the one wire versions but are there recommendations for specific alternators?
There seems to be differing opinions on the whether the load dump issue is a real concern or not. I understand Bob Nuckolls is working on a product to nullify the concern with using internally regulated alternators. Is there any news on this product at this time?
Attached is my initial swag at my electrical loads.
CH601HDS Electrical Loads Analysis1.xls |
16 KB |
671 Time(s) |
_________________ Rich Whittington
Tullahoma, TN
Zenith 601HDS
Corvair 3 Liter 120HP |
btucke73(at)yahoo.com Guest
Posted: Thu Nov 30, 2006 7:30 am Post subject: Alternator Recommendations |
I bought a 45 amp internally regulated alternator to install in my HDS Corvair, and sold it after figuring out that there is no way to make it fit under the nosebowl. If you are going with the WW Corvair conversion, the small dynamo is the only thing that will fit. Your only other option is to mount the alt in the back of the motor, which will require a little more work than just buying parts from William and bolting them on. Not too much work, but more... IMHO, load shedding, and possibly going with smaller lights, and LEDs when possible would be easier than engineering your own alternator setup.
You can purchase the overvoltage protection unit from Bob. I have it installed in my aircraft. After having a regulator fail in a Citabria, and frying the battery, I like the idea of having built in overvoltage protection. He now also has a low voltage indication BAMM unit now, but I know nothing about it other than what it says on the website.
R/
Brandon
bryanmmartin
Posted: Thu Nov 30, 2006 7:43 am Post subject: Alternator Recommendations |
You could go with a set of HID off-road lights. J.C. Whitney sells a
pair of KC Hilites for about $640. They're a bit pricey but they put
out three times the light for less than half of the current draw.
They're rated at 600,000 candle power for a 35W light.
Rich Whittington
Tullahoma, TN
Zenith 601HDS Under Construction
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Float Flyr
Posted: Thu Nov 30, 2006 11:31 am Post subject: Alternator Recommendations |
A rule of thumb is if you have a load meter then install loads only up to the capacity of the charging system. Without the load meter only install to 80%. I guess the reverse is true... without a meter and 30A of continuous use ( everything on after starting) the generator/alternator should be capable of producing 36A.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
bretttdc(at)yahoo.com Guest
Posted: Fri Dec 01, 2006 3:16 am Post subject: Alternator Recommendations |
go to www.buildersbooks.com and buy a copy of the Aeroelectric Connection. I would not recommend even an electrical engineer wire a small plane without it. On of the best specialty texts I have ever seen. Explanes the consideration for wiring small aircraft.
Brett Do not archive
Cheap Talk?
Wingrider
Posted: Fri Dec 01, 2006 4:01 am Post subject: Re: Alternator Recommendations |
Thanks for the advice, it will be a while till I'm at the engine stage but I was trying to figure out what I could use for landing lights before I closed up the wings.
The advice on the AeroElectric group is the Suzuki Sameri alternator which looks like a good option to me.
Tullahoma, TN
Zenith 601HDS
Float Flyr
Posted: Fri Dec 01, 2006 6:45 am Post subject: Alternator Recommendations |
Ac43.13.1b
Everything you will need to know about airplanes.... Electrical, avionics, metal work even tires.
Search for it online I found one a while ago in pdf format.... High speed then!
Noel [quote]
Kitfox III-A
eedetail
Posted: Fri Dec 01, 2006 8:46 am Post subject: Re: Alternator Recommendations |
The pair of 100w landing lights will be overkill in my opinion.
If money is no object go with a pair of HID lights. Xenondepot.com has
a pair for $469 plus shipping. Rated at 35w each, they draw less than 5 amps each. One is as bright or brighter than a 100w bulb. No matter how much light a landing light puts out, it only shows you what you are about to hit, nothing else.
TimE
p.mulwitz(at)worldnet.att Guest
Posted: Fri Dec 01, 2006 9:16 am Post subject: Alternator Recommendations |
Wouldn't this be just under 3 amps? (Power = Current x Voltage)
Paul
XL fuselage
At 08:46 AM 12/1/2006, you wrote:
| Quote: | Rated at 35w each, they draw less than 5 amps each.
601zv(at)ritternet.com Guest
Posted: Fri Dec 01, 2006 9:17 am Post subject: Alternator Recommendations |
The 35-watt automotive type lights I got from Harbor Freight for less than
$10 per pair seem to put out as much light as a 100-watt 4509 when I
compared them.
Robin in AR
N601ZV
Posted: Fri Dec 01, 2006 10:33 am Post subject: Alternator Recommendations |
Wouldn't it then be less that 2.5?
eedetail
Posted: Fri Dec 01, 2006 11:31 am Post subject: Re: Alternator Recommendations |
Well, yes you are both correct.
As voltage drops, current increases in order to maintain the same power.
My less than 5 amp is based upon actual measurements last nite, using only battery power, and an analog ammeter.
I found in actual practice that my 35w landing light will sometimes draw up to 5 amps and trip the breaker.
TimE
Float Flyr
Posted: Fri Dec 01, 2006 1:14 pm Post subject: Alternator Recommendations |
If the engine is not running you will only get about 11 - 11.5V from your
battery that will cause an increase in current draw. With the engine
running the buss should have around 13.8 - 14.4V th8us reducing the current
needed.
Circuit breakers protect from over current not wattage.
Noel
[quote] --
Kitfox III-A
Posted: Fri Dec 01, 2006 3:39 pm Post subject: Alternator Recommendations |
Wow! Thanks for helping us who are electron challanged.
Do not archive.
daveaustin2(at)can.rogers Guest
Posted: Fri Dec 01, 2006 4:43 pm Post subject: Alternator Recommendations |
Re this current vs. voltage vs. resistance stuff..
If the load is resistive, and the voltage drops, the current will DECREASE.
If the load is a motor, and the voltage drops, the current will usually be
higher as the motor will not reach full rpm.
Learned that 55 years ago..
Dave Austin 601HDS - 912, Spitfire Mk VIII
bryanmmartin
Posted: Fri Dec 01, 2006 11:16 pm Post subject: Alternator Recommendations |
I believe that the BULB is rated at 35W, there is a bit more power
consumed in the ballast. I ended up putting 10A fuses on my lights.
The 5A fuses would work most of the time but the surge current on
starting the lights would eventually blow them. The lights draw
around 3A steady state.
> same power.
> TimE
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
david_a_g_johnson(at)btin Guest
Posted: Sat Dec 02, 2006 3:39 am Post subject: Alternator Recommendations |
maybe I'm missing a crucial point, but if the voltage drops, then so does
the current - Ohm's Law
Dave Johnson
Float Flyr
Posted: Sat Dec 02, 2006 8:20 am Post subject: Alternator Recommendations |
What size is your wire and how long is it?
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Sat Dec 02, 2006 8:21 am Post subject: Alternator Recommendations |
Only if the resistance is constant.
Noel
[quote] --
Kitfox III-A
bryanmmartin
Posted: Sat Dec 02, 2006 9:06 am Post subject: Alternator Recommendations |
You're absolutely correct, that's why you need to know the voltage
that the power consumption figures were stated for in order to
calculate current. But you'll get close enough if you assume 12 Volts
for a 12/14 Volt system or 24 Volts for a 24/28 Volt system. It's
not necessary to know the current draw to the nearest tenth of an
Amp. You should design for at least 120% of your expected load anyway.
A resistive load will not consume the same power at different
voltages but regulated power supply might. These HID lights have a
power supply circuit between the bulb and the power source so they
are not a simple resistive load. Their power consumption curve may
not be linear with voltage. They are a whole lot more efficient at
producing light than a halogen light.
<david_a_g_johnson(at)btinternet.com>
so does the current - Ohm's Law
Dave Johnson
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
