bo124rs(at)hotmail.com Guest
Posted: Mon Nov 27, 2006 5:44 am Post subject: Prop gov. question |
Doing my final firewall forward wrapup and have this question. I need to
reorient the prop gov arm for an RV install. It looks I only need to go one
hole clockwise. Right to the point. How do I do it? Any gremlins?
http://rvflying.tripod.com/gov.jpg
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
O 360 A1A, C/S C2YK-1BF/F7666A4
http://rvflying.tripod.com/id30.html
Stay up-to-date with your friends through the Windows Live Spaces friends
list.
Hopperdhh(at)aol.com Guest
Posted: Mon Nov 27, 2006 8:05 am Post subject: Prop gov. question |
Dana,
On my McCauley governor, if I loosen all 6 allen head screws, the inner part can be set at any angle. You can put the bracket on any one of six ways. I don't know if that applies to all governors, or not.
Dan Hopper
RV-7A IO-360-A!A
In a message dated 11/27/2006 8:46:24 AM Eastern Standard Time, bo124rs(at)hotmail.com writes:
| Quote: | --> RV-List message posted by: "Dana Overall" <bo124rs(at)hotmail.com>
Dana Overall
Richmond, KY i39
http://rvflying.tripod.com/id30.html |
rice737(at)msn.com Guest
Posted: Mon Nov 27, 2006 8:41 pm Post subject: Prop gov. question |
Hey Dana,
If it is the MT gov, just cut the safety wire, loosen the screws and set the
arm at any angle you would like, retighten and safety wire.
Paul Rice
RV8-hope to fly in the late spring.
Posted: Tue Nov 28, 2006 4:14 am Post subject: Prop gov. question |
So just move the arm only?
Dana Overall
Richmond, KY i39
http://rvflying.tripod.com/blackwing1.jpg
[quote]From: "Paul Rice" <rice737(at)msn.com>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: Re: Prop gov. question
Date: Mon, 27 Nov 2006 23:40:42 -0500
Hey Dana,
the
Paul Rice
Posted: Tue Nov 28, 2006 6:28 am Post subject: Prop gov. question |
Hey Dana,
After you loosen the screws, the plate the arm shaft goes thru will move
where ever you want it. If you take the plate off, you will see it is a
very, very simply devise.
Paul Rice
tcervin(at)valkyrie.net Guest
Posted: Tue Nov 28, 2006 7:10 am Post subject: Prop gov. question |
Dana, My prop gov. from Van's came with instructions to move the plate
dependent on application which I did. Works great after 43 Hours!
Tom in Ohio
[quote] Hey Dana,
the
Paul Rice
LessDragProd(at)aol.com Guest
Posted: Tue Nov 28, 2006 9:01 am Post subject: Prop gov. question |
Hi Dana,
After looking at the picture you provided at http://rvflying.tripod.com/gov.jpg, it does NOT appear to be an MT governor.
I do not recognize the governor from the actuator arm and stop assembly in your picture.
FWIW, my guess would be to cut the safety wire and remove four screws so you can reposition the arm/stop assembly 60 degrees clockwise. Then reinstall the four screws and safety wire them.
Jim Ayers
In a message dated 11/27/2006 5:46:22 AM Pacific Standard Time, bo124rs(at)hotmail.com writes:
Dana Overall
Richmond, KY i39
Posted: Tue Nov 28, 2006 4:49 pm Post subject: Prop gov. question |
OK gang, just like the MT gov., all I had to do was remove all six screws
and rotate the holddown ring and shaft. I was worried something would come
springing out but it was no big deal. I hate opening up something I have no
idea about how it works inside.
Point of story, don't worry about rotating the aft ring..........it is a
piece of cake.
Dana Overall
Richmond, KY i39
| Quote: | From: LessDragProd(at)aol.com
Date: Tue, 28 Nov 2006 12:00:20 EST
Hi Dana,
_http://rvflying.tripod.com/gov.jpg_ (http://rvflying.tripod.com/gov.jpg) ,
governor.
your picture.
you
Jim Ayers
one
Dana Overall
Richmond, KY i39
Share your latest news with your friends with the Windows Live Spaces
friends module.
