dlm46007(at)cox.net Guest
Posted: Fri Nov 24, 2006 7:39 pm Post subject: cabin locks |
Anyone putting keyed locks on the main doors? any pictures of the inside mechanism?
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Fri Nov 24, 2006 9:01 pm Post subject: cabin locks |
I’ve been working on kitting up an install using these billet flush handles. I need a week or two more to finish up but I’ll post some pics of the handle now and follow up later with some install pics…
Steve
40205
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Friday, November 24, 2006 10:39 PM
Subject: cabin locks
| Quote: | | www.aeroelectric.com | 0123456789012345
46.12 KB |
189 Time(s) |
49.93 KB |
207 Time(s) |
LarryRosen
Posted: Sat Nov 25, 2006 5:36 am Post subject: cabin locks |
Dave,
Look at Tim Lewis' guide on using two key locks like those used on the
baggage door.
<http://home.earthlink.net/~timrv6/doorlock/door_lock.html>
Larry Rosen
David McNeill wrote:
| Quote: | Anyone putting keyed locks on the main doors? any pictures of the
inside mechanism?
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
jesse(at)itecusa.org Guest
Posted: Sat Nov 25, 2006 9:02 am Post subject: cabin locks |
We have put the extra lock that comes with the ignition/baggage set in the pilot’s door. The mechanism, when it “locks” swings the lever in the way of the geared arm that connects to the pin that locks the door. It is not very strong, but if someone wants to get it that bad, it is better that they break the lock than the door or something like that. For the right side, to prevent needing to go around and unlock, we drill a hole in the same rod just forward of the handle mechanism on the arm that pulls the from pin and stick a quick-release pin in the hole so the mechanism cannot move. That seems to work quite well.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
-- Release Date: 11/24/2006 5:20 PM
11/24/2006 5:20 PM
