		asarangan(at)YAHOO.COM Guest
				 Posted: Sun Jan 29, 2006 8:02 am    Post subject: Mod 61 - Stall warner question |
				I am confused by the Mod61A instructions. If I understand it correctly,
 the probe tube is meant to go through the spar, penetrating the
 trailing and leading rib flanges. So, what exactly is the purpose of
 the welding rod? Since this is a flexible wire,  it is going to flop
 around as you feed it in. Furthermore, the instruction says the wire
 will put a mark into the leading edge of the rib flange. How is this
 wire supposed to put a mark? Even if it did, its not going to be
 visible anyway from outside the wing skin. Ami I the only one who found
 this very confusing??
 Thanks!
 Andrew Sarangan
 http://www.sarangan.org
		NevEyre(at)AOL.COM Guest
				 Posted: Sun Jan 29, 2006 9:51 am    Post subject: Mod 61 - Stall warner question |
				The welding wire is meant to ''find'' the position of the rib, and you
 ''eyeball'' down the exposed portion of the wire, as you would a snooker cue,  and
 extend that line onto the upper wing skin, to the L / E.
 A powerfull light shining through the hole in the spar, [ with a blanket
 over your head, onto the leading edge area, as a Victorian photographer would
 have done] will also find you the rib position,,, ie the Redux bond line shows
 up as a dark shadow.
 Cheers,
 Nev.
