N777TY
Joined: 09 Apr 2006 Posts: 69 Location: Charlotte, NC
Posted: Sat Dec 02, 2006 1:18 pm Post subject: Tach pickup |
I'm wiring tach pickup wires to a switch that selects which mags gives the tach signal. This switch is right above the two mag toggle switches. Since I'm using EIS 4000, they say to wire from the P-lead through a 27k resistor to the tach selector switch.
Any concerns with just using a small pigtail off of the P-lead wire at the mag switch (going into the tach selector switch)? I'd prefer not to run another wire all the way to the mag itself just for tach signal. My concerns here are noise and functionality (eg. to ensure it works as wired up).
Also, any concerns with running the P-lead shielded wire together with the rest of wires, or should I find a separate path and firewall penetration just for these two wires?
PS. Why does 20AWG shielded wire's inner conductor appear to be thinner than regular 20AWG tefzel wire (measured diameter including insulation)? It looks the same to me as 22AWG tefzel wrapped in shielding (and my stripper won't strip it at 20AWG setting).
Thanks!
Radomir
_________________ RV-7A
N777TY |
nuckollsr(at)cox.net Guest
Posted: Sat Dec 02, 2006 2:44 pm Post subject: Tach pickup |
At 01:18 PM 12/2/2006 -0800, you wrote:
. . . suggest you wire as shown in
http://www.aeroelectric.com/PPS/Engine/Ignition/Mags_with_Electronic_Tach_A.pdf
| Quote: | Also, any concerns with running the P-lead shielded wire together with the
No. Run them together with other stuff as long as shields
are grounded as shown above.
| Quote: | PS. Why does 20AWG shielded wire's inner conductor appear to be thinner
Maybe because it's not 20AWG wire but 22AWG.
How do you come to believe that it's actually
20AWG wire. If there's a mil number on the wire
it will looke somethign like 22759/16-20-9 where
22759 is the base spec. Slash 16 is the sub spec.
20 is the AWG and 9 is color. If there's a third
dash number then it's the stripe color.
< with experiment. >
< --Lawrence M. Krauss >
N777TY
Posted: Sat Dec 02, 2006 3:22 pm Post subject: Re: Tach pickup |
Bob, many thanks for the suggestion. I like the simplicity of it very much! Wish I found this drawing before drilling a hole for the selector switch... but no biggie, the hole can be filled.
I do have a quick follow-up question -- the drawing I was using (toggle mag switches with start button) call out for 20 AWG shielded wire for P-leads... This drawing calls out for 18AWG shielded... Any concerns with using 20, which I have on hand? Or should I be ordering 18?
As for size of the wire.. I got the 20AWG shielded from B&C... Found the numbers on it and they read: M27500-20 TG1T14 So I guess it is 20AWG.. but again.. I gotta use 22 setting on the stripper to strip it..
Thanks again!
Radomir
N777TY |
klehman(at)albedo.net Guest
N777TY
bob(at)bob-white.com Guest
Posted: Sat Dec 02, 2006 4:06 pm Post subject: Tach pickup |
On Sat, 02 Dec 2006 16:44:14 -0600
"Robert L. Nuckolls, III" <nuckollsr(at)cox.net> wrote:
I use quite a bit of the 22 AWG shielded wire. The MIL spec for the
shielded wire I've been using and which seems to be commonly available
is M27500. The insulation is thinner than 22750/16. I haven't seen
shielded wire with 22750/16 conductors.
Bob W.
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
First Flight: 11/23/2006 7:50AM - 0.4 Hours Total Time
Cables for your rotary installation - http://www.roblinphoto.com/shop/
Posted: Sun Dec 03, 2006 9:00 am Post subject: Tach pickup |
At 03:22 PM 12/2/2006 -0800, you wrote:
No, the currents that flow in these wires
would be easily handled by 22AWG wire. There's
a kind of rule-of-thumb for wires under the cowl,
especially those that control the mags to make
them mechanically robust. This suggests the use
of 20 or even 18AWG wire. I've seen some drawings
call out 16AWG.
| Quote: | As for size of the wire.. I got the 20AWG shielded from B&C... Found the
Interesting. This probably speaks more to the
accuracy of the dies in your tool as opposed to
variabilities in the actual size of the wire.
Posted: Sun Dec 03, 2006 4:05 pm Post subject: Tach pickup |
On Sun, 03 Dec 2006 11:02:39 -0600
Was just inquiring as to the pedigree of the wire.
I have a spool of perfectly good wire where the
wire itself is not marked but label on the spool is
incorrect. Just asking about the data he had to
KNOW that the wire was indeed 20AWG. The source
and markings suggest the wire is the size he believes
it to be . . . which leaves tool variabilities as the
probable cause for his observations.
Bob. . .
>snip
Nope. I finally found a quick summary for the M27500 specification.
(Available at http://www.awcwire.com/pdf/CT-G4-M27500.pdf.)
M27500 can be made with any M22759 wire. M22759 with
different /no. have different insulation thicknesses. I've been
buying M27500-22TG3T14 which turns out to have M22759/18 wire in it.
That's specified by the TG.
Here are some wire outer diameters per the M22759 spec.:
M22759/16 20 AWG 0.058 - 0.062
M22759/18 20 AWG 0.049 - 0.053
M22759/16 22 AWG 0.050 - 0.053
This data is from
http://www.jaguarind.com/products/teflon/teflonwire.html
So if you have the M27500-20TG wire, the OD of the wire is identical to
the OD of M22759/16 22 AWG.
If you want M22759/16 wire in your M27500 shielded cable, it has to be
M27500-xxTExxxx.
My experience stripping the 22 AWG M22759/18 wire with the 22 AWG
setting on my stripper is that sometimes it works and sometimes it
slips. Once it's slipped, the insulation has been thinned some more
and I have to complete the strip with my el cheepo stripper similar to
your picture http://www.aeroelectric.com/articles/strippers/mvc829.jpg
Bob W.
N777TY
Posted: Sun Dec 03, 2006 4:28 pm Post subject: Re: Tach pickup |
Bob W. -- that's it. I mic'ed both tefzel 22 and this shielded 20 and they both came out at 0.050... My stripper doesn't wanna strip it at 20.. but works at 22 fine.. so I'm good to go.
I decided to keep the selector switch, as I didn't like having a live starter button... It does appear that using a 3 pole switch woudl be ideal. Since my left mag switch is close to the rib, not sure if 3 pole switch would fit in there (not sure about its size).. so this will work good.
Thanks to everyone!
Radomir
N777TY |
