DAquaNut(at)aol.com Guest
Posted: Wed Jan 25, 2006 9:07 pm Post subject: egt |
List,
On my first flight my exhaust got up to 1200 if I flew between 4200- 5200
rpm. I moved the clip down one notch, but it still goes up to 1200* Should I
move the clip down another notch.
Ed Diebel ( 447 Firefly)
jdmurr(at)juno.com Guest
Posted: Wed Jan 25, 2006 9:46 pm Post subject: egt |
I have a video tape from CPS that was done in Oshkosh in 1989. This is from the notes I took.
EGT should be at 1200 (at) Full throttle. (6,250 rpm). Never exceed 1400. Your clips effect the mixture at 3/4 to full throttle not 4,200-5,200 rpm which is why there is no change in temp.
CHT should run 300-325. Max 400-425. However the lower the better is the rule. This is an indication of adequate lubrication.
If your readings are out of the above tolerances pull the plugs and see if it is rich or lean before changing the mixture. Double check your oil mixture and oil type. This can effect temperatures too.
My 503 runs at 1200 in the range you state above, but cools down a little at full throttle. CHT is a little less than 300. I'm happy with this and the engine seems happy too!
They also said it is hard to damage an engine at less than full throttle which is why the full throttle readings are most important.
If you still aren't sure call CPS and they can help you.
Hope this helps.
John Murr
-- DAquaNut(at)aol.com wrote:
List,
EGT should be at 1200 (at) Full throttle. (6,250 rpm).Never exceed 1400.Your clips effect the mixture at 3/4 to full throttle not 4,200-5,200 rpm which is why there is no change in temp.
Hope this helps.
John Murr
--DAquaNut(at)aol.comwrote:
--Kolb-Listmessagepostedby:DAquaNut(at)aol.com
List,
Onmyfirstflightmyexhaustgotupto1200ifIflewbetween4200-5200
rpm.Imovedtheclipdownonenotch,butitstillgoesupto1200*ShouldI
movetheclipdownanothernotch.
EdDiebel(447Firefly)
Richard Pike
Posted: Thu Jan 26, 2006 6:08 am Post subject: egt |
Maybe, probably not. What is your static rpm, climbout rpm, and rpm at
full throttle in level flight?
If your full throttle rpm is over 65-6600, crank more pitch into the
prop until it gets down to 6600 or a hair less. That will drop the EGT's.
EGT's will rise and fall as you change the prop loading. There is much
on this topic in the archives.
Also you can check this page on how to read spark plugs, and how to
adjust the Rotax for different CHT and EGT readings.
http://www.bcchapel.org/pages/0003/pg11.htm
Rotax dealers like CPS and LEAF used to specify higher EGT's than they
do now. I still have their older material and it has different numbers
than they currently specify.
Richard Pike
MKIII N420P (420ldPoops)
List,
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Thu Jan 26, 2006 7:19 am Post subject: egt |
| John Murr
Hi John M/Gang:
Today we can get the lastest info right off Kodiak Research's web
site. I think it might be best to go with genuine Rotax limits rather
than a dealer's old video. But that is only my humble opinion.
Current Operator's Handbook for the 503 indicates:
Normal EGT: 860F to 1,000F
Max EGT: 1,200F with difference between cyls: 43F
Normal CHT: 350F to 430F
Max CHT: 480F with difference between cyls: 34F
I have much better luck tuning the prop to the engine and airplane,
especially two strokes, since they are so vulernable to loading. The
engineers at Rotax set up the engines to operate without retuning the
engine. Except in extreme cases, rejetting should not have to be
done. Temp changes from summer to winter, etc, can usually be taken
care of by raising or lowering the clip on the fuel needle.
This goes for changing spark plug heat range also.
All the manuals are available right here for free:
http://www.kodiakbs.com/tiintro.htm
MKIII
titus, alabama
_________________ John Hauck
Titus, Alabama |
Posted: Thu Jan 26, 2006 8:05 am Post subject: egt |
The video also said max rpm should be 6,250. So if I'm getting 6,600, which I am, and 1,200 EGT and 300 CHT, perhaps I need to add some pitch, get the rpms down to 6,300 to reduce the EGT and increase the CHT to the ranges you noted?
Also I only go full throttle at take off for less than a minute and I'm at least 1,000 AGL. Usually I run 4,500-4,800 rpm. 5,200-5,500 rpm if I need to get some where.
I have a 503 DCDI
John Murr
| John Murr
Hi John M/Gang:
MKIII
titus, alabama
The video also said max rpm should be 6,250. So if I'm getting 6,600, which I am, and 1,200 EGT and 300 CHT, perhaps I need to add some pitch, get the rpms down to 6,300to reduce the EGT and increase the CHT to the ranges you noted?
I have a 503 DCDI
John Murr
--"JohnHauck"jhauck(at)elmore.rr.comwrote:
--Kolb-Listmessagepostedby:"JohnHauck"jhauck(at)elmore.rr.com
|IhaveavideotapefromCPSthatwasdoneinOshkoshin1989.
|Ifyoustillaren'tsurecallCPSandtheycanhelpyou.
|JohnMurr
HiJohnM/Gang:
TodaywecangetthelastestinforightoffKodiakResearch'sweb
site.IthinkitmightbebesttogowithgenuineRotaxlimitsrather
thanadealer'soldvideo.Butthatisonlymyhumbleopinion.
CurrentOperator'sHandbookforthe503indicates:
NormalEGT:860Fto1,000F
MaxEGT:1,200Fwithdifferencebetweencyls:43F
NormalCHT:350Fto430F
MaxCHT:480Fwithdifferencebetweencyls:34F
Ihavemuchbetterlucktuningtheproptotheengineandairplane,
especiallytwostrokes,sincetheyaresovulernabletoloading.The
engineersatRotaxsetuptheenginestooperatewithoutretuningthe
engine.Exceptinextremecases,rejettingshouldnothavetobe
done.Tempchangesfromsummertowinter,etc,canusuallybetaken
careofbyraisingorloweringthecliponthefuelneedle.
Thisgoesforchangingsparkplugheatrangealso.
Allthemanualsareavailablerighthereforfree:
johnh
MKIII
titus,alabama
Richard Pike
Posted: Thu Jan 26, 2006 8:57 am Post subject: egt |
Sounds like a good plan.
RPM's on climb between 6250 and 6350 ought to work, and I run all those
those other RPM's as you with good success. Some folks prefer to run
their 2 strokes at 5800 rpm most all the time because supposedly that's
what the engines were designed for, however that would give me an
airspeed of around 80, and over these East Tennessee hills and
mountains, that gives me a ride that I was not designed for. Crank in a
bit of prop pitch and you will probably be satisfied.
Richard Pike
MKIII N420P
jdmurr(at)juno.com wrote:
I have a 503 DCDI
John Murr
Kingsport, TN 3TN0
Posted: Sat Jan 28, 2006 1:33 pm Post subject: egt |
Group,
Thanks to all who commented on EGT. I have a good idea of what I am
dealing with and what is exceptable. Im just waiting for better weather so I can
go to the hanger and try out my new radio and earbuds. I think they will
work well. Also has anyone figured out any way to trim the rudder other than a
trim tab????
Ed Diebel (447 Firefly)
( Started to say Through with Building, but I
guess it never really stops)
biglar
Posted: Sat Jan 28, 2006 2:05 pm Post subject: egt |
Take a look on my website, Ed. John H. has a similar setup that looks to be
a little easier to adjust. Lar.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
N78LB Vamoose
www.gogittum.com
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
beauford(at)tampabay.rr.c Guest
Posted: Sat Jan 28, 2006 3:07 pm Post subject: egt |
Brother Diebel...
You can also try a stronger rudder pedal return spring on the left side...
It helped with mine, but I
eventually ended up using a trim tab on the rudder as well...
Seems that asymetric swirling prop wash on the tail is difficult to
completely counteract... Is possible you will
still need to hold just a tad of rudder at some cruise settings... That's
why Homer invented sheep... and
then wool yarn, so he could later invent yaw strings... and then invent
Fireflys...
Nobody worth a hoot goes through life totally straight...Hang in there...
Beauford
FF#076
tkrolfe(at)usadatanet.net Guest
Posted: Sat Jan 28, 2006 5:24 pm Post subject: egt |
Beauford wrote:
Brother Diebel...
Fireflys...
Beauford
FF#076
Beauford,
RIGHT ON!!!!!!!
Terry - FireFly #95
HShack(at)aol.com Guest
Posted: Sat Jan 28, 2006 7:24 pm Post subject: egt |
In a message dated 1/28/2006 4:33:58 PM Eastern Standard Time,
DAquaNut(at)aol.com writes:
trim tab????
Maybe put a stronger spring on the proper rudder pedal?
Howard Shackleford
FS II
SC
