Ruddder Skin
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List
ceengland(at)bellsouth.ne
PostPosted: Sat Jan 28, 2006 5:22 pm    Post subject: Ruddder Skin Reply with quote
J H wrote:
I have a crack in the right rudder skin. Is there a way to repair this, or does the entire rudder need to be reskinned? Is it better to just build a new rudder? If reskin or build new, what is the best skin thickness to use? Thanks in advance.
Yours must be fairly new. Smile
Stop drill it (be sure that you drill at the very end of the crack) &
force some RTV caulk (the kind that doesn't stink, to avoid corrosion)
into the hole to act as a damper in the future.
Go fly tomorrow.
Most -4's with any time at all on them have cracks, unless the RTV was
put in the trailing edge when the rudder was built.
Charlie
- The Matronics RV4-List Email Forum -
http://www.matronics.com/Navigator?RV4-List
RV4PatA(at)aol.com
PostPosted: Sun Jan 29, 2006 2:52 pm    Post subject: Ruddder Skin Reply with quote
In a message dated 1/28/6 5:06:05 PM, rv74jl(at)yahoo.com writes:
<<I have a crack in the right rudder skin. Is there a way to repair this, >>
I had cracks in the skin at the leading edge rivet on two stiffeners. Stop
drilled the cracks and covered them with click patches from ACS. 80 hr and
still OK. Got the idea from Doug Rozendaal.
Pat Allender-RV-4
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List All times are GMT - 8 Hours
