kearney(at)shaw.ca Guest
Posted: Fri Nov 17, 2006 8:13 am Post subject: One of the best moves I've made yet |
Hi
Since starting to build a couple of weeks ago, I have limited my work to things that I felt I could do without too much risk of error. Namely, small fabrication, priming, deburring, drilling, deburring, priming. Did I mention deburring?
My plan all along was to advance enough that I could then hire an experienced builder for some detailed one on one instruction. I have just completed two very full days with this chap and now believe that I am well equipped to proceed on my own (at least for now). In October I did a two day “sheet metal course” that gave me the basics on a couple of small scale “projects – a small airfoil section being one”. It is a bit different when you are looking at a large, very expensive vertical stab skin that you have just spent hours prepping. The decision to get someone to look over my shoulder and to demonstrate [proper technique and what to look for was the best decision I have made so far. Here’s why:
On Wednesday, I started with dimpling 101. Although I had previously dimpled the rudder and vertical stab skins these did not meet the standard set by Ralph (my instructor). He demonstrated how to tell if the dimples were correctly formed and more importantly, how to correct those that weren’t. After redoing the dimpling, we moved on to backrivetting the rudder stiffeners to the skins. At that point we departed from the plans and cut an electric trim access panel into the rudder skin. Here Ralph demonstrated how to cut access panel holes without deforming the skins and getting nice clean edges. If I had tried this on my own, I would be buying a new rudder skin by now! Before starting we also discussed the location of the trim tab and we decided to move it lower on the rudder. We also gave thought to the rivet pattern for the doubler and access plate, Ralph suggesting that we consider the esthetics of matching the existing rivet pattern when placing the doubler and access panel.
Next we tackled the trailing edge of the rudder. Another builder suggested using angle aluminum to hold the trailing edge straight after the edge wedge was glued in. The problem with this was that the edge wedge is a wedge and a cleco will not sit flat on the skin due to the angle through the wedge. To compensate I used (temporarily) the horizontal stab wedge material to provide a completely flat clecoing surface. The cleco went through:
- Extra edge wedge (pointing forward)
- Rudder edge wedge (point aft of course)
- Rudder skin
- Angle aluminum
Every hole was clecoed overnight while the glue set. The next morning I had a perfectly straight rudder skin and edge wedge.
Thursday morning Ralph showed me how to use a carpenter’s angle to check that the rib flange angles were correct. This would ensure that the skins wouldn’t pucker due to the rib flanges being bent to far in/out. We riveted the trim access panel double and also fabricated a cover plate. Here I was shown how to bend the cover plate edges so that the plate would sit flat on the doubler (and the corners wouldn’t turn up).
We then discussed how the trim servo would be mounted and decided we could cut the servo cable into the skin as well given that we sorted out where the trim tab would be and how great it’s range of movement would be. I cut this hole, finished it and trimmed a rudder cable fairing to fit. We riveted it on and then stood back being quite smug with our work!
We completed the rudder back riveting and spliced the two sides together with op rivets. I then started setting the trailing edge rivets with my squeezer. After back riveting the trailing edge, I now have a rudder that is al most complete – a rudder with an arrow straight trailing edge.
Late in the day, we still hadn’t bucked any vertical stab rivets. This was the last bit of “experience” I wanted. We setup and Ralph gave me a step by step instruction on how to rivet these skins and what to be careful of so as not to dent the skins. He spent time on how to hold the bucking bar, how to ensure you are on the rivet and how to rivet very carefully. He also warned me to not use my mushroom set and to get a swivel set. After doing a few rivets, I understand why. Before we called it a day, we completed about half of one side of the stab skin. Perhaps the hardest part for Ralph was watching me rivet the forward center rivets of the skin, perhaps the riskiest of the lot. But they came out fine!
There must have been a hundred different thgings Ralh showed me including how to use my tools correctly and a few oithes to buy. Most importantly, I was able to make a lot of mistakes (not fatal) and was shown how to correct them. Also, I learned a great deal about how to work with aluminium – if nothing else, the rudder trim “extra” was invaluble in this respect.
This may be a bit rambling, but it was a fun couple of days. For any one else who has 0, zero, nadda, zilch, zippo experience like I do (did), this is a great way to build confidence and acquire skills. Unforrttunately spending two weeks a buikld center was impossible and in many respects, I believe that this approach was better. I used my tools, in my work area and I have an umbilicus to an individual who knows me and my project. The cost was also a fraction of the cost of build center.
Cheers
Les Kearney
RV10 # 40643 - Vertical Stab / Rudder in various stages of disrepair
Tim(at)MyRV10.com Guest
Posted: Fri Nov 17, 2006 2:43 pm Post subject: One of the best moves I've made yet |
Les, that sounds like a fantastic way to start off. I had an RV-4
building buddy get me started for 2 or 3 hours, and I helped on his
project for a couple hours too. It's very comforting to work with
someone with good skills and have time to learn. It sounds as if
you had a very skillful guy in Ralph. Now you can use those skills
to have a really good quality outcome on the rest of your project.
Besides that, those hours probably were more fun as well.
Les Kearney wrote:
| Quote: | Hi
* Extra edge wedge (pointing forward)
* Rudder edge wedge (point aft of course)
* Rudder skin
* Angle aluminum
build center.
Cheers
Les Kearney
