jeff(at)westcottpress.com Guest
Posted: Tue Nov 14, 2006 10:48 am Post subject: Post Component Construction Priming |
Hello Listers,
For those of us a bit less consumed with priming (as in... we're not
priming)... but wouldn't mind a some protection from corrosion, does
anyone one know of a dipping or misting process that can be used on
assembled components?
Jeff Carpenter
40304
Flaps
millstees(at)ameritech.ne Guest
Posted: Tue Nov 14, 2006 11:03 am Post subject: Post Component Construction Priming |
I used corrosionX on my Arrow. It is sprayed on with a hand sprayer, and
worked pretty well.
www.corrosionx.com/
Steve Mills
RV-10 40486 Slow-build
Naperville, Illinois
finishing fuselage
rvbuilder(at)sausen.net Guest
Posted: Tue Nov 14, 2006 11:54 am Post subject: Post Component Construction Priming |
ACF-50 is the other big one out there for corrosion protection. I
believe they both sell small versions of the FBO equipment for fogging.
Might be one of those handy tools for a chapter to get. ACF and
Corrosion-X are very similar and both work very well. They get into the
tiniest of gaps and are completely non-conducting. This is the route I
decided on way back rather than all the extra priming weight and effort.
Michael Sausen
-10 #352 Fuselage
Posted: Tue Nov 14, 2006 12:44 pm Post subject: Post Component Construction Priming |
Alodine??? Irridite??? You must rinse really well though!
Linn
Jeff Carpenter wrote:
Hello Listers,
Jeff Carpenter
40304
Flaps
Posted: Tue Nov 14, 2006 4:41 pm Post subject: Post Component Construction Priming |
Before I started on my -10, I was setting up to build the CH 640 and went to
the rudder workshop in Eastman, GA. There, on their certified Alarus
airplanes, they've set up a contraption with holes drilled in PVC pipe (call
it a "wand"), installed nozzles, and hooked up to an air pressure source.
Then they take the long wand, put Corrosion X in it, insert it all the way
down through the completed wing, begin spraying, and slowly pull it out of
the wing.
Look them up at www.newplane.com and ask for Terry (one of the owning
partners) for more specifics. Feel free to mention that I referred you. I
was also there this summer for our local EAA chapter's fly-in over there to
check out their operation. He remembered me from a couple of years before,
as my wife attended with me during the workshop. Great folks to talk to.
Rob Wright
#392
Fuse
Posted: Tue Nov 14, 2006 6:52 pm Post subject: Post Component Construction Priming |
I've been think about doing something like this with some Lowes Depot
misting nozzles adapted to some sort of tubing. The price they want for
the "paint gun" version of the foggers is nuts. If I ever come up with
something that works well I'll let the group know.
Michael
DAVELEIKAM(at)wi.rr.com Guest
Posted: Tue Nov 14, 2006 7:38 pm Post subject: Post Component Construction Priming |
Here are two options for you. I am planning on one of these products after
completion and painting.
http://boeshield.com/index.htm
http://www.nocorrosion.com/corrosion-control.htm
Dave Leikam
40496
tailcone - (dimple, dimple, dimple...)
N89DA
Muskego, WI
mike(at)cleavelandtool.co Guest
Posted: Wed Nov 15, 2006 6:29 am Post subject: Post Component Construction Priming |
We sell Boshield in small qty. for use on tools to keep them from
rusting. We are a dealer and can have gallons or 5's drop shipped
from Boeshield and possibly save some money. Email me if interested.
mike <at> cleavelandtool.com
FYI this has been my corrosion plan all along.
Cleaveland Aircraft Tool
On 11/14/06, Dave Leikam <DAVELEIKAM(at)wi.rr.com> wrote:
Posted: Wed Nov 15, 2006 9:14 am Post subject: Post Component Construction Priming |
Hi Mike,
Do you have any sense of the coverage you'll get with the Boeshield,
or, more to the point, how much you'll use on the 10?
Jeff Carpenter
40304
On Nov 15, 2006, at 6:28 AM, Mike Lauritsen - Work wrote:
<mike(at)cleavelandtool.com>
> products after
> Dave Leikam
> 40496
> N89DA
> Muskego, WI
chris(at)christopherstanl Guest
Posted: Wed Nov 15, 2006 2:12 pm Post subject: Post Component Construction Priming |
I am using a Sherwin Williams rattle can one step. I can’t remember the numbers, but it’s something like Primer no. 348. If you’re really interested, I’ll go back and get specifics for you.
Christopher Stanley
80% on empenage
deej(at)deej.net Guest
Posted: Wed Nov 15, 2006 2:28 pm Post subject: Post Component Construction Priming |
Chris Stanley wrote:
Sherwin Williams 988:
<http://www.sherwin-automotive.com/products/show_product.cfm?product=7565>
-Dj
LloydDR(at)wernerco.com Guest
Posted: Thu Nov 16, 2006 6:19 am Post subject: Post Component Construction Priming |
It is also sold at Napa as 7220, made by a division of Sherwin Williams,
and often easier to get in rural areas, because the automotive paint
stores for them are difficult to find outside of big cities
Dan
N289DT (RV10E)
Posted: Fri Nov 17, 2006 8:17 am Post subject: Post Component Construction Priming |
Lloyd, Daniel R. wrote:
Dan
N289DT (RV10E)
I just order it at this website, and have them ship it to me. No
worries about trying to find a store, or if they have it in stock.
-Dj
