jeff(at)westcottpress.com Guest
Posted: Thu Nov 16, 2006 2:22 pm Post subject: Some Observations after Two Years of Building |
Today marks the two year anniversary of the arrival of my tail kit
and it seems a good time to post some observations I've made over the
course of those 730 days:
I've put in 905 hours... an average of 1.74 per day, 5 days per
week. Not quite the 2 hours per day that I had planned. As others
have pointed out on this list from time to time, things happen over
during a project like this. Life changes, and if you're going to
finish, you will likely have to change your expectations from time to
time and keep forging ahead in any way you can. In my case, it was
severe Tennis Elbow in both arms (the result of a four hour riveting
session with my pneumatic squeezer) that cost me the better part of
three months of work and about $1,000 in physical therapy.
The DRDT-2 is a must, and with it you should dimple "missionary"
style. I spent a long time dragging skins over the male dimple
die... hunting around for the hole (all puns here are intended)...
before I realized how easy it was to dimple skins from the top down.
Time spent setting up is time saved working.
Measure three times. Cut once.
Find a comfortable position to stand in before pulling the trigger on
the rivet gun. That will save your skins as well as your back.
Some riveting simply can't be done alone
If you feel as if you are about to make a mistake, you're probably
right. Read the plans again... and again... and again... until what
you are doing becomes clear. And, remember, it's the left side
that's pictured in the plans.
If you're tired, don't work.
If it hurts, stop.
Vary your work. Don't just countersink for hours on end... or rivet
or deburr or even dimple. Repetitive tasks will take their toll over
time ( I have the elbows to prove it)
Finally, there are no "stupid" questions. None of us learn or
understand things in the same way and what might be obvious to one
person is anything but that to another. For me, it took an
embarrassing amount of time to really understand why we deburr. I
did it, dutifully, but it wasn't until I was well into the wing that
I got the mental picture of a sharp edged rib flange cutting into a
skin as the plane vibrated under power. I think we need to make a
better effort on this list to avoid jumping all over someone for
asking a question (even a priming question) just because the answer
is obvious to some of us. I have a sense that there are many
"lurkers" out there afraid to address the list for fear that they
will appear less smart or less sophisticated or just flat out
stupid. If we want a safe fleet of RV-10's flying in the future,
then we have to indulge even the most basic questions and we have to
remember that new people coming on to the list have to go through the
same discovery process as those who started it. Hats off to Tim
Olson for his contributions, but even more so for his tone. I think
it's an example we should all follow.
Jeff Carpenter
40304
Elbow braces securely fastened
Riveting the right flap
ron.mcgann(at)baesystems. Guest
Posted: Thu Nov 16, 2006 3:08 pm Post subject: Some Observations after Two Years of Building |
Excellent post Jeff. After 2.75 yrs and 2000 hrs of slow build, I can endorse everything you have said. I too have suffered significant elbow pain through repetetive tasks and posted to the list on this some time ago. Got nil response, so I thought it was just me getting old and soft. Just worked through it. I'm well into the finshing stages now, and find that the old elbows are much healthier now the edge and hole deburring (I think that's what caused me most strain) are finished.
Lurkers should be aware that building is an enormous challenge and great fun - I would definitley do it all again in an instant and will likley build another RV in the future. But there are some hazards. Crook elbows, the odd hole bored into unsuspecting fingers (and knuckles), pinching skin in the pneumatic squeezer, exposure to alodine, toluene, isocyanates, epoxies, fiberglass dust, flying debris from grinding, aluminium dust, sharp edges (esp firewall!!). . . all makes the build process that much more exciting! I think it was Rick Sked who said to call it quits for the night when you first draw blood
As pilots, I am sure we are all very safety conscious, and take every precaution during the build process. Unfortunately, s^&t happens, and you can't plan for allergic reactions and debiltating conditions like RSI.
Not intending to turn anyone off at all - but the last thing we need is to lose our medicals because of building misphaps.
build safe, fly safe
Ron
187 finishing
rvbuilder(at)sausen.net Guest
Posted: Thu Nov 16, 2006 5:22 pm Post subject: Some Observations after Two Years of Building |
I’m beginning to think we need a support group for Riveting Elbow! I too suffered this affliction but I’m too stubborn (or is that stupid) to stop working. I originally got it 15 years ago from playing Racquetball anyway. Oh well. My little 6 month break due to my move is letting it heal up finally. I guess some good advice out of this is to wear a tennis elbow brace right from the beginning.
Michael Sausen
-10 #352 Fuselage
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Thursday, November 16, 2006 5:07 PM
Subject: RE: Some Observations after Two Years of Building
Ron
187 finishing
-----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)]On Behalf Of Jeff Carpenter
Sent: Friday, 17 November 2006 8:52 AM
Subject: Some Observations after Two Years of Building
--> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com>
If it hurts, stop.
Jeff Carpenter
40304
Riveting the right flap [quote]
Deems Davis
Posted: Thu Nov 16, 2006 5:45 pm Post subject: Some Observations after Two Years of Building |
What a bunch of whiners!!!!! :-* I Had wrist / Carpel tunnel
surgery and had my forearm in a cast for 10 weeks, The Doc said "don't
lift anything more than 5 lbs for 3 months" I was riveting with the
cast on 1 week after surgery, probably not too smart, but I told you all
I am compulsive!!!!! :-!
Do Not archive
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
acs(at)acspropeller.com.a Guest
Rick S.
Posted: Thu Nov 16, 2006 7:47 pm Post subject: Some Observations after Two Years of Building |
Not to down play all the name calling He-men out there but I had 6 surgeries on my right hand since May of 2003, the last in October 2005 as a result of a crushed finger that ultimately was replaced by a nifty carbon fiber and titanium bone replacement unit (#2 to get one in the country) that will never really replace the original but beats the heck out of amputation or fusion.
So nanner nanner Deems, and your Wussy comment
Getting back to the building process was a major motivator and in between some 350 odd physical therapy appointments and work I managed to get to the point Deems is at minus a few months....
Never give in, never surrender...
Rick S.
40185
FWIW, I think Anh went through a bunch more with the torn achillies tendon...
_________________ Rick S.
RV-10
40185 |
bob.kaufmann(at)cox.net Guest
Posted: Thu Nov 16, 2006 8:17 pm Post subject: Some Observations after Two Years of Building |
Sounds like a session of I've got one better than you. Well golly, I got a
bunch of work to go do in my garage. LOL.
Bob K
90/90
Deems Davis
Posted: Thu Nov 16, 2006 8:39 pm Post subject: Some Observations after Two Years of Building |
I'm humbled................. (I Think )
Deems
Rick wrote:
Rick S.
40185
mgeans(at)provide.net Guest
Posted: Thu Nov 16, 2006 8:42 pm Post subject: Some Observations after Two Years of Building |
Jeff Carpenter wrote:
"I have a sense that there are many "lurkers" out there
afraid to address the list for fear that they will appear
less smart or less sophisticated or just flat out stupid."
Well.....Not this one!!! Type! - Type! - Type! - Lurk! -
Lurk! - Lurk! Hey! Look! I have no empenage in my garage!
I have no money in the bank yet! I have time to Type!
Type! Type! "They're comeing to take me away! HOO HOO
:-O HA HA They're taking me away to the RV farm!!!"
(the preceeding message was intended for notions of humor
and silliness and in no way should be mistaken as sarcasim.
Mr. Carpenter's well written piece on correct ergonomic
control of one's extremities should serve us all a good
notion to utilize good planning during our build and use
correct working heights for one's personal altitude that
one climbs and maintains throughout each day. It would
also be good to add the common sense of using our PPE
(personal protective equipment) when in our shop. No
elbows were harmed in the makeing of this e-mail.)
John,
Thank you for your update on your 2 year progress. It is a
good milestone to be able to look at your progress. Its
more than I can say for my progress. Let those who have
not be happy for those who do! Congradulations John!
Matt Geans,
Builder Wanna-be
On Thu, 16 Nov 2006 14:21:50 -0800
Jeff Carpenter <jeff(at)westcottpress.com> wrote:
tail kit and it seems a good time to post some
observations I've made over the course of those 730
days:
days per week. Not quite the 2 hours per day that I had
planned. As others have pointed out on this list from
time to time, things happen over during a project like
this. Life changes, and if you're going to finish, you
case, it was severe Tennis Elbow in both arms (the
result of a four hour riveting session with my pneumatic
squeezer) that cost me the better part of three months
"missionary" style. I spent a long time dragging skins
over the male dimple die... hunting around for the hole
(all puns here are intended)... before I realized how
the trigger on the rivet gun. That will save your skins
probably right. Read the plans again... and again...
and again... until what you are doing becomes clear.
And, remember, it's the left side that's pictured in
the plans.
If it hurts, stop.
end... or rivet or deburr or even dimple. Repetitive
tasks will take their toll over time ( I have the elbows
to prove it)
learn or understand things in the same way and what
might be obvious to one person is anything but that to
another. For me, it took an embarrassing amount of time
to really understand why we deburr. I did it,
that I got the mental picture of a sharp edged rib
flange cutting into a skin as the plane vibrated under
power. I think we need to make a better effort on this
list to avoid jumping all over someone for asking a
answer is obvious to some of us. I have a sense that
there are many "lurkers" out there afraid to address the
list for fear that they will appear less smart or less
sophisticated or just flat out stupid. If we want a
safe fleet of RV-10's flying in the future, then we have
go through the same discovery process as those who
started it. Hats off to Tim Olson for his
Jeff Carpenter
40304
Admin.
page,
Posted: Fri Nov 17, 2006 6:32 am Post subject: Some Observations after Two Years of Building |
HEY! I walked 5 miles, uphill both ways, to school when I was little and it was in 5 feet of snow. But I was only 4 feet tall with no shoes on!
Ah yes, this list is always good for a laugh or two. HA!
Michael
archiveer niet
보관하지 말라
não archive
μην αρχειοθετήστε
no archive
non archivii
johngoodman
Posted: Fri Nov 17, 2006 1:52 pm Post subject: Re: Some Observations after Two Years of Building |
| Rick S. wrote: | Never give in, never surrender...
Galaxy Quest!!!
I don't believe the elbow problems come from riveting. I have developed it in both elbows. I figured out that it was the cleco pliers. I sprang for a pneumatic cleco gun and it has already helped a lot.
Here's a test: put a cleco in the pliers, squeeze it, and hold. You'll feel it.
