nuckollsr(at)cox.net Guest
Posted: Wed Nov 15, 2006 7:07 am Post subject: TCAD IAS Switch (with link to sketch) |
The circuit is just a ground to tell my TCAD that it is on the ground. A
pressure switch ( I can only find NO in the range I need) is in the pitot
system. The switch closes at roughly 50 knots. I have access to both ends
of the switch. The switch is a micro pneumatic logic 503. Maybe you know a
supplier that would sell me one that is NC.The closing of the switch is
supposed to open the ground on the TCAD. I can easily convert the no to nc
by using a relay, but, I thought a transistor may also work?? Just making
an attempt to learn more electric stuff. I hope that this explanation
works.
If we knew more about the internal wiring of the TCAD system, perhaps
the solution could be as simple as the first sketch below.
(I didn't get the attachment here . . . I've posted the sketch
at: http://www.aeroelectric.com/temp/TCAD_Switch.pdf
However, the second sketch is 99.9% certain to work. All the parts are
available from Radio Shack.
< with experiment. >
< --Lawrence M. Krauss >
dsvs(at)ca.rr.com Guest
Posted: Wed Nov 15, 2006 8:55 am Post subject: TCAD IAS Switch (with link to sketch) |
Bob,
Thanks for the help. I now have one more question. I am looking at the second sketch and the two resistoirs look to be in series with the second resistor going to ground. The resistors appears to half the volltage going to the transistor when the switch is open with the other half going directly to ground. With the switch closed the voltage that would have gone into the transistor would now go to ground ? with no voltage going into the transistor? If you have time I would like to hear a little explanation of the actual workings of this circuit. I am not doubting it will work, I just want to understand what and why it does what it does. Thanks for all the help. Don
---- "Robert L. Nuckolls wrote:
works.
Posted: Wed Nov 15, 2006 7:32 pm Post subject: TCAD IAS Switch (with link to sketch) |
Bob,
Thanks for the information. I sent a previous response that I do not think
made it. In that one I asked about how and why the resistive portion of the
circuit was there. I figured it out and think that I actuaslly learned
something today. Thanks again.
Don
Posted: Thu Nov 16, 2006 2:22 am Post subject: TCAD IAS Switch (with link to sketch) |
Bob,
I sat down and examined the resistors and finally figured out that they are a voltage divider and that the total amperage down any leg in the circuit would 0.007A. I think I understand how it works now. Thanks.
Don
works.
