aeroads(at)comcast.net Guest
Posted: Thu Nov 16, 2006 3:54 am Post subject: 0-540 E vs C0-540 E vs C |
An easy way to get all the Type Certificate Data Sheets.....Google in "type certificate data sheets", conveniently gets you down a few layers in FAA.gov, in the FAA search window enter lycoming A1D5 say....you'll get the Lycoming E295 data sheet in PFD format which provides much interesting information play with it....all the TCD's are available and make interesting reading Murray
