q
Russ Kinne
PostPosted: Sat Jan 28, 2006 9:04 am    Post subject: q Reply with quote
Matt
Here we go again. Larry Bourne refers to a message from Kirk Smith/
Snuffy -- he obviously got it, but I haven't seen a bit of it.
This happens fairly often. What am I doing wrong?
Russ
Site Admin
PostPosted: Sat Jan 28, 2006 10:24 am    Post subject: q Reply with quote
At 09:03 AM 1/28/2006 Saturday, you wrote:
Matt
Russ
Hi Russ,
At this point, I am suspecting that either your ISP or your local email client has some sort of Spam filtering utility that is catching the incoming List messages. This has been the case in a couple of other instances on the Lists. Outbound List messages are marked with a "Bulk" priority and some filters will detect this as "Spam".
If you have any sort of Spam filtering software on your local PC or that is a part of you email application, you should check to see if it is nabbing the List messages. For example, the Eudora email has a really awesome spam filtering system built right in. If that's definitely not it, then I would contact your ISP and ask if they are implementing some inbound spam filter system (they probably are) and ask that they put in a never block for the matronics.com domain.
Matronics Email List Admin.
Kirk Smith
PostPosted: Sat Jan 28, 2006 10:47 am    Post subject: q Reply with quote
I didn't recieve the message from me or Big Lar either. What did he say?
Pickin on me cause I been buildin longer than he has?
Matt
Russ
biglar
PostPosted: Sat Jan 28, 2006 1:35 pm    Post subject: q Reply with quote
Breathing. Do not Archive Smile
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
N78LB Vamoose
www.gogittum.com
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
biglar
PostPosted: Sat Jan 28, 2006 1:58 pm    Post subject: q Reply with quote
Pickin' on ya ?? Hell no, you're on my side. Smile Do not
Archive.
P.S. You guys might look at the problem I found the other day. My own
address (both of 'em) was somehow put into the spam catcher. How ?? No
idea.
Larry Bourne
Palm Springs, CA
N78LB Vamoose
www.gogittum.com
Larry Bourne
Palm Springs, CA
"Vamoose"
