nuckollsr(at)cox.net Guest
Posted: Mon Nov 13, 2006 5:51 am Post subject: Grounding lugs (belated response) |
At 02:10 PM 7/16/2006 -0700, you wrote:
| Quote: | Ok, got the transponder info, now...
I am still wondering if I need to change out the 1/4" brass thru firewall
studs put in by Lancair. I am using #2 welding cable for the
batteries. If I've done the calculations correctly the diameter of AWG2
is .27", just slightly more than 1/4". Would that .02 require going to
5/16" studs?
.25 in threaded brass is pretty light mechanically. The minor diameter
of the threads is 0.2" Given our interest in gas-tight joints it's
nice to have enough strength to put some pressure on the terminals
when torqued to near max value for the fastener.
< with experiment. >
< --Lawrence M. Krauss >
blackoaks(at)gmail.com Guest
Posted: Mon Nov 13, 2006 10:11 am Post subject: Grounding lugs (belated response) |
Bob, I changed out the 1/4" brass studs for 5/16" brass as you suggest for the positive and negative thru the firewall. Thanks for the answer.
On 11/13/06, Robert L. Nuckolls, III <nuckollsr(at)cox.net (nuckollsr(at)cox.net)> wrote: | Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net (nuckollsr(at)cox.net)>
| Quote: | ....wondering if I need to change out the 1/4" brass thru firewall
5/16" studs?
John McMahon
Lancair Super ES, N9637M [quote][b]
