echristley(at)nc.rr.com Guest
Posted: Mon Nov 13, 2006 6:26 am Post subject: Joining copper wire to aluminum tube |
I'm attempting to use my pitot tube for an antennae as described here:
http://contrails.free.fr/instruments_ant_sonex.php
I'm looking for a way to reliably attach a BNC connector to the 3/16"
aluminum tube with a short jumper wire. It's to small to rivet, and I
can't crush it as it still has to operate as a pitot tube. The only
viable alternative I've identified to date is aluminum brazing rod.
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o http://ernest.isa-geek.org |
sportav8r(at)gmail.com Guest
Posted: Mon Nov 13, 2006 7:03 am Post subject: Joining copper wire to aluminum tube |
You might try the flux paste for aluminum made by Solder-It company.
I've torch-soldered to aluminum wwith fair success using this. Once
the flux/solder paste adheres to the aluminum, you can pretty much
join any other solderable metal to it at that one spot.
I bought mine online from the company, but I've since seen it at
Lowe's. Can't recall if Lowe's had only the silver solder paste,
which won;t help you, or the aluminum paste, which is what you need.
-Bill B
On 11/13/06, Ernest Christley <echristley(at)nc.rr.com> wrote:
rparigor(at)SUFFOLK.LIB.N Guest
Posted: Mon Nov 13, 2006 10:08 am Post subject: Joining copper wire to aluminum tube |
Hello Ernest
A few ideas that fell out of my head:
Use a copper pitot tube if you can
www.McMaster.com sells conductive epoxy (ain't cheap)
Buy 1 foot of Erics Copper coated aluminium wire (get both sizes if strand
sizes are different) and sand off copper so you have an aluminium to
aluminium joint, the other end you can crimp or solder, see if you can
clamp with a few aluminium clamps like adel or make some, could also put 4
strands, with lets say 1 inch contact at 12,3,6 and 9 O-Clock and wrap
with Spectra fishing line, or Size E Dacron thread, or probably even
cotton sewing thread and put a drop of Model thin CA to hold in place.
Better? Do the 4 strands of Eric aluminium wire with 1.5" contact area.
Heat shrink a 1/4" band on each end and one in the middle to hold in
position for wrap. After wrap is complete heat shrink the whole thing
(adhesive lined for good seal) or paint with something as CA is not
waterproof.
Ron Parigoris
