N777TY
Joined: 09 Apr 2006 Posts: 69 Location: Charlotte, NC
Posted: Mon Nov 13, 2006 7:26 pm Post subject: ring terminal |
Any thoughts about putting a 1/4" ring terminal (for 8 awg wire) onto a #10 (approx 3/16" dia.) stud on the fuse box? Is that a no-no?
Thanks!
_________________ RV-7A
N777TY |
nuckollsr(at)cox.net Guest
Posted: Tue Nov 14, 2006 5:52 am Post subject: ring terminal |
At 07:26 PM 11/13/2006 -0800, you wrote:
Thanks!
Obviously, a 'connection' will be made and the terminal
is not at-risk for falling off. But keep in mind that
terminal application is tailored around the idea of
achieving gas-tight connections in the mating parts.
Gas-tight connections require optimized force being
exerted over a terminal area. The peak forces within
a bolted stack up of terminals happens right around the
stud . . . if the hole in the terminal is oversized, then
we've compromised design goals for the product.
Are you likely to experience any difficulties for the
compromise? No. But it IS a compromise and not the best
we know how to do.
< with experiment. >
< --Lawrence M. Krauss >
