capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Sun Nov 05, 2006 11:10 pm Post subject: aileron throw |
Can anyone (rv10) with their wings on tell me how much throw is in
the control stick in the aileron direction? Probably be easiest to just
measure from left sidewall to the stick deflected to the left and the
distance from the left sidewall to the stick with right deflection of
aileron. I'm scratch building a panel and need to ensure clearance.. thx
Steve d
40205
No virus found in this outgoing message.
ScooterF15
Posted: Mon Nov 06, 2006 5:39 am Post subject: aileron throw |
Steve,
I don't have my airplane handy, but I want to point out that I had to cut around 3 or 4 inches off the top of each stick for clearance reasons. That makes a big difference in clearance. Make sure that you take that into account when someone gives you a full left to full right measurement.
Jim
In a message dated 11/6/2006 2:12:47 A.M. Eastern Standard Time, capsteve(at)adelphia.net writes:
| Quote: | --> RV10-List message posted by: "Steven DiNieri" <capsteve(at)adelphia.net>
Steve d
40205
No virus found in this outgoing = sp; (And Get Some AWESOME FREE find fts ic you for nbsp; -Matt Dralle, List es Day --> ===
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
jesse(at)itecusa.org Guest
Posted: Mon Nov 06, 2006 6:34 am Post subject: aileron throw |
Although I understand the concern, I don't think I would worry too much
about having full travel, because except during your control check, I can't
imagine EVER going full travel on the controls (especially since we aren't
aerobatic). Moving two inches to the left or right will get you into a
pretty steep turn, and two inches forward or back will get you very
nose-high or nose-low. We also cut the sticks all the way down and put the
Infinity Aerospace grips as far down as they will go to clear the panel, but
if we ever got close to the panel in flight, the moron flying would be
trying some kind of snap-outside-loop or something, which I certainly would
not want to be a part of. Pulling all the way back on landing is the only
one that would be common, when you flare.
Just IMHO, so do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
flysrv10(at)gmail.com Guest
Posted: Mon Nov 06, 2006 6:41 am Post subject: aileron throw |
With the elevator in neutral and full left aileron, the distance from the stick to the left fuselage skin is 5". Full right aileron, measured at the same spot, it is 17.5"
do not archive.
Rob Kermanj
On Nov 6, 2006, at 2:09 AM, Steven DiNieri wrote:
[quote]--> RV10-List message posted by: "Steven DiNieri" <capsteve(at)adelphia.net (capsteve(at)adelphia.net)>
Steve d
40205
-- Please Support Your Lists This Month --
(And Get Some AWESOME FREE Gifts!)
November is the Annual List Fund Raiser. Click on
the Contribution link below to find out more about
this year's Terrific Free Incentive Gifts provided
by:
* AeroElectric www.aeroelectric.com
* The Builder's Bookstore www.buildersbooks.com
* Aeroware Enterprises www.kitlog.com
* HomebuiltHELP www.homebuilthelp.com
List Contribution Web Site
Thank you for your generous support!
-Matt Dralle, List Admin.
- The RV10-List Email Forum -
--> http://www.matronics.com/Navigator?RV10-List
AV8ORJWC
Posted: Mon Nov 06, 2006 7:30 am Post subject: aileron throw |
Sergei Boriak (Russian Aerobatic Champion) locked our stick grip (in a
Red Star Aircraft)under the instrument panel during Aerobatic Dual
maneuvering. No one thought it was possible. It leaves a life altering
experience. The maneuver set up the scenario. The aircraft contortion
closed the distance. Metal has memory, Metal flexes and bends.
Although the RV-10 will seldom be in aerobatic configuration. I would
never design an aircraft which could get in that stick configuration
again. "Design for Aerobatic, Load for Utility, fly in Normal
configuration". Adrenalin can be a great thing as your life passes in
your hand(s) while you say - "Damn!"
I want full ability to input full UNRESTRICTED control movement to
correct any conceivable configuration and I want it "NOW". Sorry Jesse,
now offense intended.
"Safety first, safety always".... I like your question Steven. Design
for all possibilities, not just the common ones. Just IMHO. Sounds
like the answer from Rob is 12.5" from full left to full right or 6.25
left and right of neutral. Any second confirmations? I believe the
elevator movement is greater and that one needs posting that as well due
to contact with the center of the switch panel.
While we are at it, could we get a Full rudder forward and Full rudder
aft measurement too? That means Rudder stop to Rudder stop but measured
at the foot pedals.
John Cox
(503) 453-6016
Do not Archive
sschmidt(at)ussynthetic.c Guest
Posted: Wed Nov 08, 2006 2:21 pm Post subject: aileron throw |
You definitely do not want your stick hitting anything at all. My stick
was hitting on full down because of my Aerocrafters panel that hangs
about 1.5 inches lower than the stock panel and the Infinity grips are a
little taller. I had to higher a tig welder to come out and weld about
a 1 inch extension to the stick which brings it back, away from the
panel. Now during my preflight I can work the control surfaces with full
deflection and not hit anything.
N104XP - 35 hours
Scott Schmidt
sschmidt(at)ussynthetic.com
AV8ORJWC
Posted: Wed Nov 08, 2006 7:35 pm Post subject: aileron throw |
Scott, on a light hearted note. Since no one is responding to stick
travel fore and aft or rudder pedal travel.
If you had a welder place a 1.5" extension to correct the high grip,
Wouldn't that grip hit the equipment between your legs or was that
picture from the back seat (over six months ago) representative of
additional long legged clearance.
Still wondering fore to aft travel. And I still have your avgas money
in escrow for the first Grand Champion award. Casa Grande was not the
same without you.
N49CX - not yet flying
John Cox
Do not Archive for obvious reasons
capsteve
Posted: Thu Nov 09, 2006 12:07 am Post subject: aileron throw |
Thanks for the info.
I measured the rudder pedals from the firewall mounted in full aft position (I’m short)
Left pedal 4” – 10” right pedal 4.5” – 11” measured on pilots side
Also rudder cable travel is 4 1/2” stop to stop as measured from the clevis hole in the rudder
Steve d
40205
do not archive.
Rob Kermanj
11/4/2006
11/8/2006
wv4i(at)bellsouth.net Guest
Posted: Thu Nov 09, 2006 3:01 am Post subject: aileron throw |
Sorry, but I have to chime in with John C. on this one. You should NEVER
have restricted control movement by design. While it is true that the
control stick box, rudder travel for that matter, is/are normally rather
confined, especially at higher airpspeeds, there ARE situations, and in
other than aerobatic flight, where full control movement may be
required. I encourage anyone considering restricted control movement, by
design, to give this latter point serious consideration.
Example, and on the lighter side, a wake turbulence encounter.... A
neighbor, the other day, reported substantial wake turbulence and
control recovery effort after being "thumped" by an F-15 whilst on final
to our airport. What TFR? What presidential visit in progress some
12-15nm away, hi? Intercept procedures and required response, huh?
Anyway, point is to always consider the unexpected, and in this case the
need for full control authority, always.
Link McGarity
#40622 elevators
RV6/N42GF/flying, non builder
bldgrv10450(at)comcast.ne Guest
Posted: Thu Nov 09, 2006 5:47 am Post subject: aileron throw |
Thanks Steve:
For rudder control I am planning to start with new steel cross tubs and fabricate new drops for relocation of the rudder cables into the center of the tunnel. Additionally, I am working on a single center drop arm for each pedal. The finish should be lighter weight, more foot room, and vanity covers for master cylinders and hoses. A plus if I can work it out might be easy adjustably. I will post pictures as this takes shape.
Paul Grimstad
RV10 40450
Portland, OR 97219
Posted: Thu Nov 09, 2006 1:53 pm Post subject: aileron throw |
Now I have to be very careful how I answer this. I don't want to just
say that there is plenty of clearance, but I also don't want people to
think I didn't think through this and engineer it so that it does hit.
Hahaha
No, there is plenty of clearance for me. Now if you were pretty short
with a large gas tank for a sex machine (beer belly) you may have some
problems when you pull the stick back all the way. But so far everyone
you has flown it has plenty of clearance.
I sure wish Van would have had adjustable rudder pedals like the RV-8
though. It would have give people more options for proper adjustment.
Scott Schmidt
