Posted: Wed Nov 08, 2006 3:26 pm Post subject: Glueing foam ribs in HS and Elevator - Pro-seal or ? |
Vans specs Pro-seal. I see a number of people have used RTV silicon
adhesive. Thoughts?
- Though I've never handled it, Pro-seal seems messy - but made to
withstand flexing, heat, and other a/c conditions
- Various silicon adhesives are available at the local airplane stores
(Lowes) - suitability not know by this builder
I'm looking for some opinion. Thanks
Bill Watson - Elevator, QB in transit, still acquiring tools and technique
http://www.mykitlog.com/MauleDriver/
mike(at)learningplanet.co Guest
Posted: Wed Nov 08, 2006 4:42 pm Post subject: Glueing foam ribs in HS and Elevator - Pro-seal or ? |
Hi Bill,
I have used ProSeal and have been happy with the results. Yes, it
smells weird and is messy, but it's not too bad. You know it will
work and won't crack. One less thing to worry about.
Mike Schipper
RV-9A - N63MS - Flying
RV-10 #40576 - Wings on the way
http://www.rvten.com
On Nov 8, 2006, at 5:25 PM, MauleDriver wrote:
silicon adhesive. Thoughts?
stores (Lowes) - suitability not know by this builder
technique
patrick.pulis(at)seagas.c Guest
Posted: Thu Nov 09, 2006 2:35 am Post subject: Glueing foam ribs in HS and Elevator - Pro-seal or ? |
G'day mate from downunder, wear two pairs of gloves and use old rags to
wipe everything up with Toluene and you'll be OK.
The end result is worth it.
Pat
RV-10 40822
Adelaide, South Australia
