pj.ladd(at)btinternet.com Guest
Posted: Sat Oct 28, 2006 2:14 am Post subject: test |
messages to another list are still working as normal.
Seems to be a problem on this list only and I have not changed anything at
this end.
Help
Pat
Mike Schnabel
Joined: 27 Jan 2006 Posts: 114 Location: Manchester, TN
Posted: Sat Oct 28, 2006 3:36 am Post subject: Test |
Pat...
That messsage come through on this end!
What did you do different??
Mike S
Manchester TN
Firestar 2 503
Posted: Sat Oct 28, 2006 4:21 am Post subject: Test |
Eugene Zimmerman
Posted: Sat Oct 28, 2006 5:26 am Post subject: test |
anything at this end.
Help
Pat
biglar
Posted: Sat Oct 28, 2006 3:11 pm Post subject: Test |
It did it again, Pat. The message before came thru fine, now this one is
blank again. Dunno what to tell ya. Lar. Do
not Archive.
Larry Bourne
Palm Springs, CA
www.gogittum.com
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
Posted: Mon Oct 30, 2006 9:04 am Post subject: test |
I have made some changes at Matte`s suggestion. Is this OK?
Please respond
Pat
rlaird
Posted: Mon Oct 30, 2006 9:24 am Post subject: test |
perfecto!
-- R
On 10/30/06, pat ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote: Quote: | I have made some changes at Matte`s suggestion. Is this OK?
Please respond
Pat
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
dcarr(at)uniontel.net Guest
Posted: Mon Oct 30, 2006 9:30 am Post subject: test |
rlaird
Posted: Mon Oct 30, 2006 9:45 am Post subject: test |
Ut oh.... here we go again... David has contracted the "Pat disease."
-- R
On 10/30/06, David Carr < dcarr(at)uniontel.net (dcarr(at)uniontel.net)> wrote:
Robert Laird
Houston, TX area
a58r(at)verizon.net Guest
Posted: Mon Oct 30, 2006 10:36 am Post subject: test |
L & C here
regards,
Bob N. FireFly 070 Old Kolb
Posted: Mon Oct 30, 2006 11:28 am Post subject: test |
Please respond
Pat
Patrick:
Glad the test period is over, for email that is.
Now.........when are you going to fly your mkIIIx?
DO NOT ARCHIVE
_________________ John Hauck
Titus, Alabama |
Posted: Mon Oct 30, 2006 12:21 pm Post subject: test |
Bet it works better now!!! I changed to plain text!
DEC
[i]----
Russ Kinne
Posted: Mon Oct 30, 2006 1:30 pm Post subject: test |
Came in loud and clear!!Best,
Russ
Please respond
Pat
Posted: Tue Oct 31, 2006 12:34 am Post subject: test |
.when are you going to fly your mkIIIx?>>
Hi John,
Matte came up with a fix. Seems that there was some double encapsulation
(whatever that is) going on.Luckily a computer guy was here today installing
a new comp for Wendy and we concluded that Matte was right and we corrected
it by removing the outgoing virus check on my machine.... seems to have
worked.
Re the plane. I have elected to buy a `quickbuild kit`, which has now been
approved for use in the UK. This means that I shall have a more or less
complete wing turn up which will only need covering, instead of a pile of
tubes. Transport charges are based on the weight and size and as the main
spar dictates the size the difference in transport costs should not be too
much different.
Works were starting to build my wing about the 4th Oct. so I hope that it
is on the high seas by now.
I have been drilling out rivets today so that I can detach the old aileron
for use on the new wing.
After a superb autumn with a lot of absolutely still, clear days when I have
had nothing to fly, the weather has now changed and apart from the odd day
the winter has arrived, so realistically it is a matter of having the newly
repaired plane ready to go when the weather breaks in the Spring.
The clocks went back last weekend so it is now dark by 6 o clock. It is
still quite warm, unseasonably so, around 15/17 C but beginning to look
forward to drawing the curtains, getting the log fire going and a house
full of family for Christmas.
It will soon be Spring. I hope!. I hope!. I hope!
Jim Baker
Posted: Wed Nov 08, 2006 2:52 pm Post subject: test |
test
Jim Baker
580.788.2779
Elmore City, OK
Posted: Wed Nov 08, 2006 3:08 pm Post subject: test |
L & C
regards,
