dav1111(at)cox.net Guest
Posted: Tue Nov 07, 2006 3:56 am Post subject: Before closing up the top of the TailconeBefore closing up t |
I installed my most forward cross member as close to the F-1006 as possible, and just behind the bolts joining the F-1046 and F-1032 Longerons together, almost directly above the battery. I have had no problems with interference, except where I failed to use brass bolts and washers to install the magnameter onto the shelf.
Since the duel AHRS and magnameters are all on a shelf next to each other in the center of the fuselage the left and right seat belt cables just cross above the cross members and are no problem. If you were to install the AHRS or magnameter next to the fuselage side wall they could cause interference.
Best regards,
Russ Daves
N710RV flying
DO NOT ARCHIVE
jjessen
Posted: Tue Nov 07, 2006 7:47 am Post subject: Before closing up the top of the TailconeBefore closing up t |
So, is there a reason to locate where Russ has done, or to locate behind the F-1007, further away from the battery? I'm trying to keep the area above the battery free for a future hat shelf, but don't want to place things too far aft if there is a reason one should keep the AHRS and magnetometer closer to, say, the mid of the plane. If either is back further into the tailcone, could that mess up their readings?
John Jessen
40328 (closing the tailcone as soon as I locate the shelf for the AHRS/magnetometer)
| Quote: | From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Russell Daves
Sent: Tuesday, November 07, 2006 3:55 AM
Subject: Re: Before closing up the top of the TailconeBefore closing up the top of the Tailcone
Best regards,
Russ Daves
N710RV flying
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.kitlog.com">www.kitlog.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
| -- No virus found in this Edition. Release Date: 11/6/2006 |
No virus found in this outgoing message.
11/6/2006
apilot2(at)gmail.com Guest
Posted: Tue Nov 07, 2006 11:03 am Post subject: Before closing up the top of the TailconeBefore closing up t |
Be careful. I would expect the exterior skins in that area to be
considered part of the stressed monocoque. Might be better to have
access panel as part of the rear baggage compartment panel, as many
Cessnas do.
On 11/7/06, Deems Davis <deemsdavis(at)cox.net> wrote:
Something I was reminded recently of was the issue of serviceability.
There is a lot of space behind the baggage bulkhead, and potentially
room for things like Oxygen, air Conditioning, AHRS, Strobe power
supply, ELT, Elevator servo, Batteries, contactors, etc. etc. With the
tailcone disconnected, and with the top fuse skin at the rear of the
cabin off, it's easy to get to these areas, but how will that be
accomplished when everything is riveted/bolted up, just a thought to
throw into the mix, its caused me to think seriously about adding a
hinged access door/panel that would be located behind the baggage
bulkhead top skin and forward of the tailcone top skin.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
> John Jessen
> AHRS/magnetometer)
> *From:* owner-rv10-list-server(at)matronics.com
> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
> *Russell Daves
> *Sent:* Tuesday, November 07, 2006 3:55 AM
> *To:* rv10-list(at)matronics.com
> *Subject:* Re: Before closing up the top of the
> Best regards,
> Russ Daves
> N710RV flying
>href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
> 11/6/2006
owl40188(at)yahoo.com Guest
Posted: Tue Nov 07, 2006 12:33 pm Post subject: Before closing up the top of the TailconeBefore closing up t |
I second that. I would be very careful putting any access panels in the outer skins.
Niko
40188
Posted: Tue Nov 07, 2006 8:55 pm Post subject: Before closing up the top of the TailconeBefore closing up t |
Perhaps, but do you want to be the designer? I don't know how critical
those areas are.
I know you can safely go through the back panel of the baggage
compartment..maybe not as convenient, but a lot less risky to the
structure when you need to do a high G pull out.
Good point Kelly !, thanks for keeping this Dreamer grounded in a safer
reality. Could it be accomplished by installing sufficient doublers
around the opening? And rather than making it hinged, using closely
spaced nutplates to attach the access?
Deems Davis # 406
> Cessnas do.
>> Deems Davis # 406
>> > John Jessen
>> > AHRS/magnetometer)
>> > *Russell Daves
>> > Best regards,
>> > Russ Daves
>> > N710RV flying
>> > 11/6/2006
