thilo.kind(at)gmx.net Guest
Posted: Sat Jan 28, 2006 9:22 am Post subject: Tow bar - nose gear stop |
Hi folks,
quite a while back we discussed the issue of the nose gear bungee breaking. Some of you had developed a safety stop, so that the nose gear won't go through the upper skin.
One of you designed a safety stop, that also serves to connect a tow bar. I'm very interested in the design, since I'm installing wheel pants, thus my old tow bar design wouldn't work anymore.
Thilo Kind
CH601 HDS
Larry McFarland
Joined: 10 Jan 2006 Posts: 36 Location: East Moline, Illinois
Posted: Sat Jan 28, 2006 5:44 pm Post subject: Tow bar - nose gear stop |
Thilo,
I did my safety stop/tow bar ring from an example provided by Bill
Morelli. The T-bar handle is thin 4130, 5/8-inch o.d. with an aluminum tube
riveted between it and a tube welded to a tapered flat with a 2-inch
slot and side pieces also slotted for the AN3 screws.
The ring, 3/8-inch thick, 2-inch i.d. and 3-inch o.d. was milled,
drilled and tapped to accept the connecting AN3 bolts front and rear.
The ring is cut in two
after turning and machining is complete. Wish I had better pictures to
offer right now, but you get the idea from the links below,
http://www.macsmachine.com/images/wheelfairings/full/fairingflangeassy.gif
http://www.macsmachine.com/images/gear/full/travelstop.gif
Larry McFarland at www.macsmachine.com
Thilo Kind wrote:
Hi folks,
Thilo Kind
CH601 HDS
_________________ Larry McFarland - 601HDS - Stratus |
Billvt
Posted: Sun Jan 29, 2006 8:15 am Post subject: Tow bar - nose gear stop |
You can check out my nosegear stop at my web site (address below)
Click on construction and then bungee stop - tow bar
Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 441.6 flight hrs. - 598 landings
web site -> http://homepages.together.net/~billvt/
