toaster73(at)earthlink.ne Guest
Posted: Tue Nov 07, 2006 7:04 pm Post subject: Before closing up the top of the TailconeBefore closing up |
I'd consider the ability to keep it water tight as well.
One other way of thinking about these considerations is just to not bother
planning ahead. Just finish the airframe and then install the various
pieces of gear. then you will be sure that it can be serviced later and you
will have figured out the best way to contort yourself to get at it for the
future maintenance.
-Chris Lucas
#40072 (cabin side skins)
