Bandsaw dimension question
sonexplus(at)libero.it
PostPosted: Mon Nov 06, 2006 12:59 pm    Post subject: Bandsaw dimension question Reply with quote
Hi,
I'm a new CH-701 scratch builder and i'm starting to cut of cutting and
forming blocks...
What are the recomended dimensions for a bandsaw throat opening and for the
sawing material thick?
And the Sander? Only disc or disc/belt sander? Suggested disc dimension?
What about this two in one:
http://cgi.ebay.it/SEGA-A-NASTRO-CON-LEVIGATRICE-INCORPORATA-REXON_W0QQitemZ190048238559QQihZ009QQcategoryZ20785QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Thanks in advance.
Bruno Melegari
Italy
Setting up my workshop...
dredmoody(at)cox.net
PostPosted: Mon Nov 06, 2006 1:45 pm    Post subject: Bandsaw dimension question Reply with quote
I'm not a scratch builder, Bruno but I do woodwork and I have used my sears bandsaw and a disc sander, bench grinder style lathe with scotchbrite wheels (one coarse and one fine) extensively during kit building a 601XL. For the bandsaw, get as much throat depth as you can afford. you will cut plastic fairleads, wood forming blocks, aluminum sheet and extrusion pieces so get multiple blades to allow fast rough cuts on wood and fine finish cuts on all materials. I drill press will come in very handy as well.
Any combo belt / disc sander will serve you well, but don't skip the lathe with scotchbrite wheels. That is a great way to produce factory looking parts that aren't prone to cracking over time.
He who dies with the most tools wins.
Ed Moody II
Rayne, LA
601XL/Jabiru/cabin area
---- Bruno <sonexplus(at)libero.it> wrote:
Hi,
forming blocks...
Thanks in advance.
Bruno Melegari
Italy
nfivesl(at)yahoo.com
PostPosted: Mon Nov 06, 2006 1:52 pm    Post subject: Bandsaw dimension question Reply with quote
Hi Bruno:
Don't waste your money on that Ebay junk. You need a full-size band saw (12"). Mine is here and it worked great:
http://www.cooknwithgas.com/Bandsaw.jpg
The refrigerator in the background is not necessary.
Also, don't buy a small, cheap sander (ask me how I know). I have this one and it is great:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=43468
I sand Chrome-moly or wood with this one and it works very well.
This was the first sander I bought and it is junk: http://www.cooknwithgas.com/Sander.jpg
Same thing on the band saw. The little saws don't work well.
So in both cases, 12" works for the sander and band saw.
Scott Laughlin
601XL/Corvair Plans-Builder
Finishing up BRS Installation
zodierocket(at)hsfx.ca
PostPosted: Mon Nov 06, 2006 2:18 pm    Post subject: Bandsaw dimension question Reply with quote
Ed Moody II
Rayne, LA
Yup , buddy walks through garage door the other day and announced that
I may die now I have already won. I looked at him and said yes but for
where I'm going I need a lot more to build a ladder.
Cdngoose
No virus found in this outgoing message.
11/4/2006
pacificpainting(at)comcas
PostPosted: Mon Nov 06, 2006 2:20 pm    Post subject: Bandsaw dimension question Reply with quote
I think what you meant to say is, "The refrigerator in the background is
mandatory". You don't have to thank me for correcting your error.
Dave in Salem where it is breaking records for rainfall already.
ter_turn(at)yahoo.com
PostPosted: Mon Nov 06, 2006 2:44 pm    Post subject: Bandsaw dimension question Reply with quote
Bruno, if you're poor like me you can get buy with a handheld jig saw and an air/electric angle grinder. The belt sander is almost indispensable though. If you can't afford an air compressor you can get a riveting attachment for your drill. Ha, Ha, you can probably build the airframe for six grand if you scrounge hard enough!
Terry Turnquist
601 XL Plans
St. Peters, MO
[quote]--> Zenith-List message posted by: "Bruno"
Hi,
forming blocks...
And the Sander? Only disc or disc/belt sander? Suggested disc Sponsored Link
[url=http://o1.qnsr.com/cgi/r?;n 3;c 32538;s 14;x=7936;f 0611011404190;u=j;z=TIMESTAMP;]Get an Online or Campus degree - Associate's, Bachelor's, or Master's - in less than one year.[/url] [quote][b]
Chris Lewis
PostPosted: Mon Nov 06, 2006 2:45 pm    Post subject: Re: Bandsaw dimension question Reply with quote
Bruno - Not sure if you can get one of these Ridgid sanders on the continent, but it is THE machine for scratch builders. I've made all of my forms on a 10" Craftsman bandsaw and this sander. It does the bevels and the crimp locations with ease.
Chris in Seattle
 Filesize:  20.11 KB
 Viewed:  353 Time(s)
750/ Zen-vair Semi-Scratch Builder
N750XT (reserved)
p.mulwitz(at)worldnet.att
PostPosted: Mon Nov 06, 2006 2:48 pm    Post subject: Bandsaw dimension question Reply with quote
Hi Bruno,
I guess I will weigh in on the tools. I am not a scratch builder,
but I have been buying and using machine tools for a lifetime.
First the easy one - I bought one of the $100 combination belt and
disc sanders by Delta sold at Lowes. I use it all the time for
shaping parts after rough cutting them with a band saw or other
technique. I never use the disk, but the 42" belt sander has a great
cast iron work support which is just the thing for grinding relief
angles on forming blocks.
The band saw is a lot harder. You can buy one of these for prices
ranging from under $100 to the price of a new house. I would suggest
you limit your choices to saws that have blade guides both above and
below the work support table. If it turns out this makes the choices
too expensive for your budget then do without the band saw all
together. It is not necessary anyway. If you want a slightly slower
cutting saw with a more natural ability to cut a straight line then a
nice scroll saw might work better for you. Again there is a Delta
scroll saw available at Lowes for around $100 with a cast iron table
that might work well for you.
In my shop, the drill press gets the most use. This is followed (in
order) by the little belt sander, the band saw (for rough cutting
only), and then the scroll saw. I have not used my wood lathe yet
for aircraft purposes, and only have used the metal lathe and milling
machine for making my own tools.
The tool that gets the most work building a metal airplane is your
hand held drill. This is where you should spend the most time
finding the choice that feels best in your hand. It will be your
partner throughout the building process.
Good luck,
Paul
XL fuselage
P.S. On the few occasions I made forming blocks, I used hardwood
plywood 3/4" thick with great results.
At 12:57 PM 11/6/2006, you wrote:
Hi,
and forming blocks...
for the sawing material thick?
craig(at)craigandjean.com
PostPosted: Mon Nov 06, 2006 4:31 pm    Post subject: Bandsaw dimension question Reply with quote
I bought a cheap Ryobi 10 inch band saw from Home Depot. Its instructions
specifically say "for cutting wood only" and it only came with wood blades.
That being said it was so cheap that I still use it for cutting metal and
will throw it away when it wears out. It did take a bit of searching to find
fine-toothed blades to cut metal on it. It does have top and bottom guides
and has held up well so far but I am not a scratch builder.
-- Craig
601zv(at)ritternet.com
PostPosted: Mon Nov 06, 2006 5:41 pm    Post subject: Bandsaw dimension question Reply with quote
I've been using the same machine and it's been doing quite well with 14 TPI
blades also from Homely Depot.
rstone4(at)hot.rr.com
PostPosted: Mon Nov 06, 2006 5:49 pm    Post subject: Bandsaw dimension question Reply with quote
Craig,
Here is a URL for a company that has every size band saw blade there is
and their prices are very good. They also fill orders on the same day as
they are received. When the people who made your saw put the notice, "For
wood cutting only" they must have been refering to the blade that came with
it.
http://www.woodworker.com/
Bob Stone, Harker Heights, Tx
ZodiacXL
PostPosted: Mon Nov 06, 2006 7:44 pm    Post subject: Bandsaw dimension question Reply with quote
http://oneworld1.inetu.net/manuals/index.php?dir=ryobi/&file=BS1001_269_eng.
pdf
(Quote from page 17)
APPLICATIONS
You may use this tool for the purposes listed below:
- Scroll cutting and circle cutting of wood and wood composition
products
- Relief cutting of wood and wood composition products
I think they were a little concerned with the dust collection system too.
Not that I have let this stop me.
This is where I bought my fine-toothed blades: www.ebandsawblades.com/
-- Craig
PostPosted: Mon Nov 20, 2006 12:24 pm    Post subject: Bandsaw dimension question Reply with quote
Thanks a lot Scott.
Bye
Bruno
