nuckollsr(at)cox.net Guest
Posted: Wed Nov 08, 2006 6:47 am Post subject: Reasonable qualification for flight hardware? |
At 07:23 AM 11/8/2006 -0700, you wrote:
Quote: | I am testing out a new LED comet-like flasher and 48-diode lamp to be used
as a beacon under a clear rudder tip fairing. Both are inexpensive
Chinese imports designed for automotive application. Brightness and flash
rate/pattern are very good, but I was wondering what is a "reasonable"
test period to run the thing on the ground before installing one in the
OBAM plane? 100 hours, 2000 hours?
Why not use the OBAM aircraft as the test bed. It's
your airplane and nothing is preventing you from using
whatever lighting schemes you choose.
Quote: |
Clearly it should also depend on whether there is any failure, whether the
failure is the lamp or the flasher, and whether it is a single diode burn
out or total failure. Also, after the testing, which will not be
comprehensive like a commercial venture (no statistics here), would it be
preferable to install the already-tested hardware or a completely new set?
Is it your desire/intent that this product meet
FAA requirements for lighting under FAR91? That's
a wholly different ball game. Here the questions are
not so much one of service life but of gross intensity
along the various axis external to the aircraft. A really
tedious test to do and requires some equipment with
reasonable expectations for accuracy.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
N6030X(at)DaveMorris.com Guest
Posted: Wed Nov 08, 2006 9:15 am Post subject: Reasonable qualification for flight hardware? |
You probably need to find out whether the FARs on light intensity
apply to experimental aircraft or not. Google around a bit, because
some pretty smart people have already done a lot of testing of LEDs
for use in aircraft external lighting.
It is common in the electronics manufacturing world to do "burn-in"
testing for at least 2 or 3 days, during which time the device is
cycled on for a few hours, off for a few hours, preferably including
and possibly exceeding the temperature ranges in which the device is
likely to be operating. Most electronic component failures are
infant-mortality type, meaning that if they survive a few days of
intensive testing, they will probably last a long time.
Dave Morris
be used as a beacon under a clear rudder tip fairing. Both are
inexpensive Chinese imports designed for automotive
application. Brightness and flash rate/pattern are very good, but I
was wondering what is a "reasonable" test period to run the thing on
the ground before installing one in the OBAM plane? 100 hours, 2000 hours?
whether the failure is the lamp or the flasher, and whether it is a
single diode burn out or total failure. Also, after the testing,
which will not be comprehensive like a commercial venture (no
statistics here), would it be preferable to install the
Any guidance here?
Andy Elliott
N601GE (601XL/TD, Corvair, building)
bakerocb
Posted: Thu Nov 09, 2006 8:45 am Post subject: Reasonable qualification for flight hardware? |
11/09/2006
Responding to a previous posting by Dave N6030X <N6030X(at)DaveMorris.com
Hello Dave Morris, You wrote: "You probably need to find out whether the
apply to experimental aircraft or not."
This is a question that has no clear cut answer. Let's examine the
regulatory issue in the context of exterior lighting:
1) The Operating Limitations for each ABEA (Amateur Built Experimental
Aircraft)** include the following sentence: "After completion of Phase I
flight testing, unless appropriately equipped for night and/or instrument
flight in accordance with 91.205, this aircraft is to be operated under VFR,
day only."
2) To the FAA this sentence means that if the ABEA is operated day VFR that
none of the instrument and equipment requirement provisions of FAR 91.205
would apply.
3) This means that during day VFR operations not even FAR 91.205 (b) (11)
regarding the requirement for an anticollision light system would apply.
4) But as soon as the aircraft is operated at night or in instrument flight,
either day or night, the provisions of FAR 91.205 (b) (11), (c) (2) and (c)
(3) regarding exterior lighting would apply.
5) Each of the subparagraphs listed in 4 above contain the word "approved".
6) But since there are no published certification standards for ABEA there
is no criteria available to measure approval against and one could conclude
that any exterior lighting on an ABEA would be acceptable.
7) But logic raises the issue of interface with other aircraft.## The
purpose of exterior lighting is to permit other observers in the air and on
the ground to see the ABEA and react accordingly. If the ABEA is
inadequately lighted then a hazard to others could exist .
This line of reasoning would permit the initial airworthiness inspector
to examine the exterior lighting of the ABEA with regard to its adequacy.
The inspector could conclude, if exterior lighting is present, that the
builder intended to operate the aircraft at night or in instrument
conditions and that therefore some specified level of performance should be
attained by that lighting.
9) A reasonable level of lighting performance to be expected could be
equivalent to that required of type certificated aircraft.
10) It is unlikely that the inspector would have either the equipment or the
inclination to actually measure the exterior lighting performance during his
initial airworthiness inspection.
11) One course of action for the inspector to ensure that the ABEA lighting
installed would meet some accepted performance standard would be for him to
require the ABEA to have installed exterior lighting approved for
installation in type certificated aircraft.
12) The issue may become confused if the builder installs some new
technology lighting (like LED's) that to any unbiased observer is obviously
superior to conventional lighting, but does not carry any kind of FAA
approval marking. To what extent is the initial airworthiness inspector
willing to sign off such lighting?
So I think that the answer to your question: "Do the FARs on light intensity
apply to ABEA or not?" depends upon the actions of the individual initial
airworthiness inspector. It may also be possible that an FAA inspector
during a ramp inspection could raise this issue.
OC -- The best investment we will ever make is in gathering knowledge.
**PS: Some people prefer the more benign sounding, but less precise term,
OBAM (Owner Built And Maintained) aircraft.
##PS: There are other items of ABEA equipment where interface with other
aircraft or the ATC system require specified levels of performance. Some
that come to mind are communication radios, altitude encoders, transponders,
navigation equipment, and ELT's. In most cases the easiest way to ensure
that specified levels of performance will be met is to install approved
equipment such as that marked to meet a TSO (Technical Standard Order)
Time: 09:15:45 AM PST US
Subject: Re: Reasonable qualification for flight
hardware?
Dave Morris
frank.hinde(at)hp.com Guest
