Dsyvert(at)aol.com Guest
Posted: Thu Nov 09, 2006 6:06 pm Post subject: Salt water environment? |
Group,
I need to get this off my chest. I may be a product of the public school system, but the engineering school I attended taught that water evaporates and salt does not go into the vapor phase. When we talk about salt water environment for primers, etc. we are really talking about areas of high humidity vs. areas of low humidity. Exhibit number one. The Great Salt Lake in Utah. Why does it not evaporate? If you want to see a real salt water environment travel to Chicago after a big snow storm and see all the salt on the roads that sprays salt water and corrodes cars. Here in Houston there are many more old cars around than in Chicago where I use to live.
The reason I posted this is that we need to talk about the cause of corrosion "high humidity" not salt water environment.
BTW, I plan on using an epoxy primer. I've debated which if any primer with myself a lot. My reason is that the RV-10 is a high dollar kit plane. If I ever sell mine then no one will ever question epoxy primer.
Sorry about the ranting, but I read about salt water environments on Van's Air Force forums as the reason for primers. Am I missing anything here?
Dave Syvertson
RV-10 Tail kit
Posted: Thu Nov 09, 2006 7:36 pm Post subject: Salt water environment? |
I think it is the salt water *mist* rather than water vapor. I'm not
sure those are the right terms but I do know that areas near ocean surf
have lot's of salt mist. It collects on practically all surfaces. That
may not be the case where there is little surf and therefore perhaps not
the case around the Great Salt Lake.
When I was shopping for a Maule, I ran across an aircraft in inland GA.
It had been refinished and was less than 10 years old. However, even to
my untrained eye, I could see a great deal of corrosion around the
interior airvents which were the only unfinished aluminum parts in
sight. I presumed it was a 'Florida' plane. Never confirmed my
suspicion but I've owned a similar Maule for 10years and there is no
sign of similar corrosion on the same parts.
do not archve
Dsyvert(at)aol.com wrote:
| Quote: | Group,
primer.
anything here?
Dave Syvertson
RV-10 Tail kit
ericmpmail-rv10(at)yahoo. Guest
Posted: Thu Nov 09, 2006 8:29 pm Post subject: Salt water environment? |
Dave,
Think of salt in the air as an aerosol, similar to the
soot from a forest fire, or dust from a dust storm,
pollen in the air, etc. Wind across the ocean forms
waves, breaking waves send up a spray of salt laden
water. Much of this falls back to the sea, but the
smallest can be carried far inland depending on winds,
etc. Once salt gets on a surface, it is very hard to
get rid of.
Now that winter is upon us, a reminder than unvented
indoor space heaters using kerosene put out a trace
amount of soot that is not good to breathe and also
can effect the adhesion bond of fiberglass laminates.
I understand it was a particular issue in the scratch
built composite days (Long-ez, etc). I don't think the
RV-10 has any structural laminations so not as much of
a concern. (Cabin top comes "done").
Eric
--- Dsyvert(at)aol.com wrote:
| Quote: | Group,
about the cause of
environment.
epoxy primer.
Dave Syvertson
RV-10 Tail kit
armywrights(at)adelphia.n Guest
Posted: Thu Nov 09, 2006 8:33 pm Post subject: Salt water environment? |
U.S. Army has a requirement to write up any time an aircraft flies closer
than 10 miles to salt water, to alert maintenance for a wash or other
preventative measures.
Rob Wright
