Jerry Cochran
Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
Posted: Thu Nov 02, 2006 10:30 am Post subject: Wings install |
Listers,
Going thru the wing install, I had a conversation with Gus at Van's and he pointed me here...
http://www.vansaircraft.com/pdf/Wing_%20Incidence.pdf
This is a valuable addition to the wing install instructions in the manual and I highly recommend you insert these pages in same, and read carefully whilst measuring the wings for sweep, incidence, etc. before drilling. I also found it valuable to use water levels or a digital level. Water levels tho, are even more accurate. I made mine from thin plastic tubing (AV dep't (at) Home Depot of course).
Here's the text from Van's PDF for your convenience...
HTH,
Jerry Cochran
n616tb(at)btsapps.com Guest
Posted: Fri Nov 03, 2006 8:47 am Post subject: Wings install |
Jerry,
This is a very good document and one I will use to check my plane over carefully. Thanks for posting it.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jerry2DT(at)aol.com
Sent: Thursday, November 02, 2006 10:29 AM
To: rv-list(at)matronics.com
Subject: Wings install
Listers,
HTH,
Jerry Cochran
0123456789012345
