Scratch in Brake Line
owl40188(at)yahoo.com
PostPosted: Thu Nov 02, 2006 6:53 am    Post subject: Scratch in Brake Line Reply with quote
While trying to install some brake lines this morning I noticed that I had a scratch on the brake line in the tunnel that I had installed some time ago. Its about 1/4 inch from the end of the tube and it might possibly be from the flaring tool. Does anyone know or have experience as to the criticality of this? Does the line need to be replaced?
thanks
Niko
40188
patrick(at)joburgonline.c
PostPosted: Thu Nov 02, 2006 7:15 am    Post subject: Scratch in Brake Line Reply with quote
Hi
Brake pipes – or bundy tube, is highly resistant to corrosion, and there shouldn’t be a problem. If the scratch is deep, and you feel uncertain, rather replace, as pressures in the braking system (open to correction) can exceed 120 bar.
Patrick Green
patrick(at)joburgonline.com (patrick(at)joburgonline.com)
http://joburgonline.com
+27 11 672 8037 (Tel)
+27 11 672 8036 (Fax)
Patrick_Green_(patrick@joburgonline.com).vcf
 Filename:  Patrick_Green_(patrick@joburgonline.com).vcf
 Filesize:  441 Bytes
 Downloaded:  276 Time(s)
