nuckollsr(at)cox.net Guest
Posted: Thu Nov 02, 2006 6:16 am Post subject: battery cable routing |
| Quote: | Comments/Questions: I have a Glastar which is both a composite fuselage
design with a steel cage. The Batteries are located in the rear and #2
cables run forward to firewall. You mention that we need to run cables
together. I'd like to run them together but split them so the (-) cable
goes to left side of firewall and the (+) cable goes to the B&C ground
block on the right. Im going with all electic plane per you design. Is
this a problem or should I run them to the same side of the
firewall? Thank You, Scott
Run them together as far as practical. Then splitting at
the firewall is fine.
( Experience and common sense cannot be )
( replaced with policy and procedures. )
( R. L. Nuckolls III )
