Posted: Tue Oct 31, 2006 9:03 am Post subject: Metal Chip chasing in the empannage area |
As you said, I can't get a large enough clamp in to place to keep the skin
tight to the backing structure to prevent the chips from dropping between.
I have chip chaser but it is too thick. I am thinking of purchasing some
long chisel shaped X-acto blades and thinning then down with a sander so
they will go between the skin and the supporting structure. I should be able
to push them out from under the skin/longeron space.
Other ideas welcome.
John G. 409
| Quote: | From: Rick <ricksked(at)earthlink.net>
Subject: Re: Empennage gap seal.
Date: Tue, 31 Oct 2006 11:15:32 -0500 (EST)
John,
I use a chip chaser, I thought it was a waste of $10 originally but it does
work well. Even better is to prevent the chips in the first place. I mask
off any cracks and such when possible to prevent them from dropping in in
the first place...not always an option though.
Rick S.
40185
