daveleikam(at)wi.rr.com Guest
Posted: Tue Oct 31, 2006 9:31 am Post subject: Project insurance during the build |
How is everyone insuring their project while building? I was told by my agent that my home owners does not cover the project without a rider. When do I need to get normal hull insurance? After certification and airworthiness? Now?
Dave Leikam
#40496
N89DA Reserved
Tailcone in clecos
dlm46007(at)cox.net Guest
Posted: Tue Oct 31, 2006 9:45 am Post subject: Project insurance during the build |
contact Falcon Insurance (EAA) for builders insurance. 1% per year of value.
Rick S.
Posted: Tue Oct 31, 2006 9:58 am Post subject: Project insurance during the build |
Dave,
Your agent is correct, and lots-o-luck getting a rider for aircraft.
Coverage is called builders risk, coverage is only for no movment type of damage, i.e. fire, theft etc.
AIG, EAA should have options for you.
You may be required to provide a reserved "N" number to bind coverage. Expect to pay $400 to $500 a year.
New program I am associated with on the near horizon (days) to consider more to follow.
Hull coverage is not mandatory, liability coverage is mandatory at most airports to operate or park. Your finance company, if applicable, most likely will require you to have hull coverage to protect their financial interest by becoming the named insured/lien holder on your hull coverage.
Rick S.
40185
Producer of Insurance
Nevada
_________________ Rick S.
RV-10
40185 |
Posted: Tue Oct 31, 2006 10:01 am Post subject: Project insurance during the build |
Is this the case if you are building in your home??
| Quote: | From: "Dave Leikam" <daveleikam(at)wi.rr.com>
Reply-To: rv10-list(at)matronics.com
Subject: Project insurance during the build
Date: Tue, 31 Oct 2006 11:31:09 -0600
airworthiness? Now?
Dave Leikam
#40496
N89DA Reserved
Tailcone in clecos
rvbuilder(at)sausen.net Guest
Posted: Tue Oct 31, 2006 7:13 pm Post subject: Project insurance during the build |
It's pretty much your choice. The only time you are really forced to get any insurance is if you have a lien against the aircraft. Otherwise you can self insure if you really wanted. Avemco has building insurance for about $1 per $100 of your stated value (need receipts). I added builders insurance a couple months back when I made the decision to move from TX to WI. For one the project is still down there so I have no control over anything going on where it is stored and for two, it will be covered while in transit as I move it up here in about 3 weeks. Prior to that I didn't feel the risk was outweighed by the expense. You are correct thought that it is unlikely your homeowners insurance would cover it. Just like it wouldn't cover your car if a tree fell on your garage while it's parked inside.
Michael Sausen
-10 #352 Fuselage
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Tuesday, October 31, 2006 11:31 AM
Dave Leikam
#40496
N89DA Reserved
Tailcone in clecos
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Tue Oct 31, 2006 7:25 pm Post subject: Project insurance during the build |
AAA (California) advised me that the contents of the shop (on same property
as house) are covered up to the same limits as the dwelling.
Kevin
40494
tail/empennage
| Quote: | >How is everyone insuring their project while building? I was told by my
>airworthiness? Now?
>Dave Leikam
>#40496
>N89DA Reserved
>Tailcone in clecos
_________________ Kevin
40494
do not archive |
Deems Davis
Posted: Tue Oct 31, 2006 8:11 pm Post subject: Project insurance during the build |
Get it in writing
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
KiloPapa wrote:
property as house) are covered up to the same limits as the dwelling.
Kevin
40494
tail/empennage
> <indigoonlatigo(at)msn.com>
>> Dave Leikam
>> #40496
>> N89DA Reserved
>> Tailcone in clecos
DAVELEIKAM(at)wi.rr.com Guest
Posted: Tue Oct 31, 2006 8:26 pm Post subject: Project insurance during the build |
Where are you in WI? I am in a suburb SE of Milwaukee.
Dave Leikam
Muskego, WI
40496
tailcone
Rick S.
Posted: Wed Nov 01, 2006 8:18 am Post subject: Project insurance during the build |
Kevin,
As Deems said get that in writing because Coverage for contents or Coverage C almost always excludes vehicles and many time it specfically states aircraft and aircraft parts in the exclusions. Tools also have coverage limits which are in the good ole fine print just as jewelry does. Standard coverage amounts are anywhere from $2000 to $5000 but you can purchase more. Your policy may have provided for $150,000 under contents or Coverage C but only provides limited amounts of that coverage for certain things (tools, jewelry, collectibles)
FWIW, understanding what's covered is much easier to understand than what is excluded (not covered) from coverage. These items, depending on the creativeness of the policy writer may be listed in a seperate section, called exclusions, WAAAAAAAAYYYYYY back in the policy.
Well written policy's usually list exclusions right after they list what IS covered and WHAT they will pay.
Which leads me to my next favorite word....PERILS!!!!! But that's another topic.
PS-Your builders risk coverage may not protect you in the event of flood waters, only water accidently discharged from a fresh water source under pressure and even then the ensuing mold may be an issue depending on your policy
Rick S.
40185
RV-10
40185 |
KiloPapa
Posted: Wed Nov 01, 2006 8:52 am Post subject: Project insurance during the build |
Thanks for your input. I'll check into it further.
Kevin
40494
tail/empennage
40494
do not archive |
jennyrvlist(at)hotmail.co Guest
Posted: Wed Nov 01, 2006 1:21 pm Post subject: Project insurance during the build |
Yes that is true the EAA does offer a builder risk policy from Global
Aerospace to EAA members for a premium of 1% of the value you choose, but
they also attach a components endorsement that breaks down the value you
choose. So each part of the aircraft is only covered for the percentage they
say. I am attaching a copy of the endorsement. For those of you that have
the higher priced items already, AIG offers a builders policy that will
cover the aircraft from a starting value not to an ending value, the policy
may be a little higer in premium but all the parts are covered in full not
to exceed the ending value you choose. AIG also covers the transportation
of the aircraft.
Jenny Estes
NationAir Insurance
(877) 475-5860.
[quote]From: "David McNeill" <dlm46007(at)cox.net>
Subject: Re: Project insurance during the build
Date: Tue, 31 Oct 2006 10:44:58 -0700
value.
EAA_Components_endorsemen_xls.xls |
15.5 KB |
352 Time(s) |
Posted: Wed Nov 01, 2006 2:55 pm Post subject: Project insurance during the build |
Shiocton, WI. It's about 15 miles north of Appleton and has a airport with a great grass strip. http://www.airnav.com/airport/W34
Michael
Sent: Tuesday, October 31, 2006 10:26 PM
Dave Leikam
Muskego, WI
40496
tailcone
KiloPapa
Posted: Wed Nov 01, 2006 6:25 pm Post subject: Project insurance during the build |
You are right. After digging in the policy I found "aircraft" listed in the
items not covered despite what the AAA (California) agent told me.
Kevin
40494
tail/empennage
Kevin,
topic.
policy
Rick S.
40185
40494
do not archive |
