CJohnston(at)popsound.com Guest
Posted: Mon Oct 30, 2006 4:12 pm Post subject: closing out floors and wire running |
Hey Tim -
I was getting ready to close up my floors, and wondered about hooking up
coax for the comms on the belly. I noticed that you ran some tubing
through bushings - did you run the wire later? Did you have trouble
fishing the wire through the hole on the bottom skin when it came time
to install the antennae? I'm just a bit confused here and I don't want
to be drilling out rivets... also, if you had to do it differently -
would you change antenna choices at all?
Any thoughts are appreciated!
cj
#40410
fuse
www.perfectlygoodairplane.net
Posted: Mon Oct 30, 2006 4:17 pm Post subject: closing out floors and wire running |
Whoops - meant to send that to Tim Olson directly, but I'd appreciate
everyone's input as well!
cj
#40410
fuse
Tim(at)MyRV10.com Guest
Posted: Mon Oct 30, 2006 4:29 pm Post subject: closing out floors and wire running |
I ran the tubing down in that area so it would hopefully make the wire
shoot out of the tubing and real close to the exit hole. In practice,
it did take me 3 or 4 minutes to get the wire fished through, because
I was off a bit on the tubing angle, but it could be done more
accurately than I did without much work. I just grabbed it with one
of those little claw grabbing tools from an auto parts store and pulled
it right out. It makes for good future access to install the connector,
without having to have an access panel under the seat...which is another
option that some have done.
As for antenna choices, I can say that I'm *almost* 100% satisfied
with the antenna choices and locations. The only one that has been
giving me grief is my Comant combo antenna (WSI/GPS). That particular
antenna has failed once (the GPS part failed), and the replacement
has been acting the same now. I'd get them to swap it, but
hopefully within a couple short months I'll be installing a
new GPS/Sirius antenna for the upgraded WSI, so it'll be irrelevant.
Other than that, I don't have any complaints. I can't believe
how much better the range of my signals is than my old plane.
As for the wire under the rear seats, I've had another builder who
did it that way report back that he had great success too. So, just
try to do it as best you can so the wire exits near the hole, and
you'll be just fine. Remember that you'll have a 5/8-3/4" hole
or so for the exit, so there's room to grab a wire.
Chris Johnston wrote:
Hey Tim -
cj
#40410
fuse
