fuel system AN- bulkhead fittings, part II
hdwysong(at)gmail.com
PostPosted: Mon Oct 30, 2006 10:34 am    Post subject: fuel system AN- bulkhead fittings, part II Reply with quote
Sorry for the bad question and confusion. I'm finishing the
plumbing on a custom fiberglass tank (not for a Europa) and
am looking for general "lessons learned" for installing the
AN fittings.
Did you simply drill the wall of the tank or fill neck and
install the fittings with the AN nut? Was any sort of
hardpoint or bulkhead (flox or aluminum) used? What about
large washers? Are your holes drilled net or are they
tapped to receive the AN fitting? Jos mentioned using
redux. Is that used on the outside to "seal" the fitting in
place? Any other "gotcha!"'s I'm missing?
Thanks for any info/tips you're willing to share.
D
grahamsingleton(at)btinte
PostPosted: Mon Oct 30, 2006 12:51 pm    Post subject: fuel system AN- bulkhead fittings, part II Reply with quote
D
You don't say how the tank is made. I guess it is vinyl ester
resin/glass cloth but does it have a foam core?
I just drilled the tank, (polyethylene) then pushed in the AN fitting
with a large washer each side and screwed on the nut. Warming the PE
helps soften it to get a good flat contact both sides.
In your case something similar but using Redux420 or whatever they call
it now, to form a fuel tight seal should work. You might try an O ring
in a chamfered recess to seal the tank.
Graham
D Wysong wrote:
Sorry for the bad question and confusion. I'm finishing the plumbing
on a custom fiberglass tank (not for a Europa) and am looking for
general "lessons learned" for installing the AN fittings.
Did you simply drill the wall of the tank or fill neck and install the
fittings with the AN nut? Was any sort of hardpoint or bulkhead (flox
or aluminum) used? What about large washers? Are your holes drilled
net or are they tapped to receive the AN fitting? Jos mentioned using
redux. Is that used on the outside to "seal" the fitting in place?
D
