owl40188(at)yahoo.com Guest
Posted: Mon Oct 30, 2006 7:05 am Post subject: Hole for break fitting in landing gear mount |
I tried to install the 45 degree break fitting thats on the lower skin/ landing gear mount this morning. Thats the one which needs a 5/8 inch hole in the skin. It appears that the hole in the landing gear mount is too small for the fitting. There is no mention in the manual about having to enlarge the landing gear fitting hole.
Has anyone else had this problem?
Niko Napoli
40188
Rick S.
Posted: Mon Oct 30, 2006 7:31 am Post subject: Hole for break fitting in landing gear mount |
Niko,
It's due to the powder coating, I used a Dremel tool to remove the coating and it fit perfectly. I quick shot of gray primer to stop it from rusting should preceed installing the fitting.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
cnm(at)willitsonline.com Guest
Posted: Mon Oct 30, 2006 7:45 am Post subject: Hole for break fitting in landing gear mount |
just get the unibit on it
mine was the same
Posted: Mon Oct 30, 2006 8:46 am Post subject: Hole for break fitting in landing gear mount |
Thanks for the info.
Niko
40188
