Posted: Mon Oct 30, 2006 11:09 am Post subject: Empannage gap seal. |
Okay, I am going to do a public gripe.
I am just about to finish section 12 and was amazed at how my entire day
yesteray was spent placing nut plates on the VS and the HS. After
completing this I finally got to the area in the plans to finish the
empannage gap plate.
One page 12-5 there is a bolt typed warning the says, DO NOT DRILL SKINS OR
LONGERONS OF THE EMPANNAGE UNTIL PAGE 12-6.
The next step say dril one of the longeron holes. Go figure?????
Okay, so I left it for later.
Finally on to page 12-6 and things are flowing. I drill all the longeron
holes to #36, debur and bla,bla, bla.
Next step, drill to #27 the empanage gap plate holes and ....... My
daughter comes down to say we are going out to dinner and I go and drill the
longeron holes also to #27, (like we have been doing with the other areas
that received nutplates.) Now, I had read ahead the night before, and
realized these longeron hole would be taped to receive the screws directly,
but I kept remembering the entire time this warning as mentioned above.
Since these hole should never have been drilled to #27, WHY DID THIS WARNING
EVER SAY WHAT IT SAID???????
All is not lost, I had to order some 4mm flat head screws and a tap so that
the holes drilled to #27 in the longerons would not have to be enlarged
anymore. Unfortunately the head angle is 90 degrees and not 100 degrees but
I can fix this. I just didn't want to go up to #8 pan heads or use
nutplates on the inside of the longerons. Trying to not remove the HS and
disconnect the trim cables, again, again, again,.....
Good Grief Charlie Brown!!!!!!
John G.
