		frank.hinde(at)hp.com Guest
				 Posted: Fri Jan 27, 2006 9:06 am    Post subject: Wheelpants and leg fairings RV 7a |
				Morning all,
 Fitting up my wheelpants and noticed from the drawing that you have to
 lift the plane off its gear so the tires are off the ground. I have one
 trolley jack and its not immediately apparent how I would do this?
 I notice what sounds like a fairly involved procedure to align the leg
 fairings...probably cus I didn't understand it on the first read
 through...Can anyone expain a simple procedure?
 I am thinking of using #6 screws and C/s washers rather than rivets to
 mount the pants..Any reason why not?
 Looks like a fair bit of work but I'd like to get everything done before
 I take the plane to the hangar.
 Frank
 RV7a..Final engine connections, bodywork, paint..Sell other
 airplane...and fly..
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		deruiteraircraftservices( Guest
				 Posted: Fri Jan 27, 2006 9:25 am    Post subject: Wheelpants and leg fairings RV 7a |
				Hi frank,
 the idea is to lift the airplane clean of the ground supported by trestles
 or similar. Align the main fairings to the centrelign of the aircraft. You
 can measure from centreline outboard on both sides and mark your H-stab. Use
 a piece of string over the centre of the pant and align with your mark on
 the h-stab. Now set the horizontal alignment. Pilot drill with 3/32 and use
 a cleco this way you have some leeway of adjustment. The holes in the pants
 can be filled with a little epoxy adhesive should you get it wrong. (but we
 never make any mistakes).
 hope this helps.
