k9hxt(at)sbcglobal.net Guest
Posted: Thu Jan 26, 2006 7:31 am Post subject: Garmin Xponder & Dynon EFIS |
Has anyone installed a GTX-327 Garmin Transponder and interwired it (RS-232) with the DYNON D10-A EFIS Encoder?? What set-up parameters did you use in each to get the Garmin to display Pressure Altitude etc. First install with full digital stuff !!
Larry, RV-6A (at) 2R2, mentored a RV-8 flying, and a RV-7A in assm'y at hngr.
"LIMA TANGO SENDS"
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
rv-9a-online(at)telus.net Guest
Posted: Thu Jan 26, 2006 1:07 pm Post subject: Garmin Xponder & Dynon EFIS |
Larry Rush wrote:
| Quote: | Has anyone installed a GTX-327 Garmin Transponder and interwired it
"LIMA TANGO SENDS"
Yes, I have.
On the D10A serial output menu, set 'FORMAT 4'.
On the GTX-327, choose either ICARUS or SHADIN format (I forgot which).
As for the other settings, you'll have to play around. I've attached
the GTX 327 install guide (on your private email, it will get stripped
on the list).
If this does not work, let me know and I'll copy the settings down when
I get to the airport.
It all works fine once you program it.
Aside: The only peeve I have is that the GTX-327 can't take serial GPS
data from a Garmin GPSMap 296! This data is used to determine automatic
STBY mode for takeoff/landing. Garmin assumes you have a 430, and won't
talk to non-IFR GPSs.
Vern Little
RV-9A 90577 C-FRVL
> Thanks,
hngr.
> "LIMA TANGO SENDS"
