fuel system AN- bulkhead fittings
hdwysong(at)gmail.com
PostPosted: Sun Oct 29, 2006 10:50 am    Post subject: fuel system AN- bulkhead fittings Reply with quote
Looking at Jos' and Graham's fuel system pics I noticed bulkhead AN fittings in several places. What method is used to install these in the Europa? Thanks for the insight!
D
josok-e(at)ukolo.fi
PostPosted: Sun Oct 29, 2006 12:51 pm    Post subject: fuel system AN- bulkhead fittings Reply with quote
Hi D,
Not quite sure what you are asking for.
Using a spanner is probably not the right answer?
Sealing where needed was done with redux.
D Wysong <hdwysong(at)gmail.com> kirjoitti Sun, 29 Oct 2006 20:49:26 +0200:
fittings
D
Kind Regards,
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http:www.europaowners.org/kit600
mono xs, top on, gear in, tail wheel in, wings set, flapdrive in, tail
closed, tailwheel in, tail top in, blue stuff filled, sanded and primed,
fuel system in, doors done, windows in, sanding and filling the fuse and
wings.
grahamsingleton(at)btinte
PostPosted: Sun Oct 29, 2006 4:54 pm    Post subject: fuel system AN- bulkhead fittings Reply with quote
Dave
You need to buy the bulkhead fitting, elbow and the nut and a couple of
washers, they are all listed in the ACS catalog.
You will need a flaring tool to fit the aluminum pipe. Best to borrow
one from your local A&P or your tech councillor
Graham
D
